AH67AH
The track rod on my BJ8 is adjusted as far as it will go, and there is still 1/4" toe out. The steering arms are the correct part numbers and on the correct side, and bend toward the backing plates. The steering and idle arms also bend toward the outside. Everything looks perfect. Is there something I'm not thinking to check? All I can figure is that the track rod itself is too long, or the rod ends are incorrect. The track rod is 19 5/8" from tip to tip. When it bottoms out in the rod ends, there are still a couple threads showing past the nuts on each side. The rod ends are marked "CG3807". The dust caps on them say "ENGPRODUCS" and are made in England.
Can anyone tell me if these rod ends are correct? I don't want to shorten the rod if the ends are the problem.
Thanks for any input.
