paintless dent removal tools?
70herald
Well a neighbor just backed into my minivan. Now if I get this door really repaired properly I am going to have to do something about the rest of the sorry looking paint job. Any experience with the "paintless dent removal tools"? There seem to be 3 basic types, a slide hammer, a sort of screw thing with a bridge and some sort of mechanical contraption with a lever.
Any experience with these? there are no creases so it seems like it might be worth a try to get it back near to its prior state.
DavidApp
Those PDR guys can do amazing things. Got some hood damage on our Chevrolet Impala fixed a few years ago. A piece of truck tire was thrown up and hit the hood. After about an hour you could not see any evidence of the damage.
Seems they spend most of their time at dealerships getting out little dings.
David
70herald
Well since the closest person really advertising as "PDR" is probably several thousand miles away I probably won't do that :grey: I guess I will have to go around to a few more places and see what they can (or are willing to do)
JPSmit
You can buy kits really inexpensively on Amazon - and youtube is your friend here. Why not buy a kit and try yourself? You really have nothing to lose. If it doesn't work you are out $50 - if it does work you have a new skill. Go for it!
HealeyRick
Popeye
Bronze
Even if the closest advertised PDR place is far away, it might be worth visiting a local body shop and get their impression. I'd assume any body shop wants to make repairs as quickly as possible, and PDR is a "tool" in their tool chest - just not the only tool.
pkmh Paintless ding removal Austin Healey 17
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
5 crease/dent in inner fender? Triumph 5
M TR2/3/3A TR3 Rear inner fender dent repair Triumph 8
mgb4tim T-Series Wind Blocker Scratch and Dent Offer - redux MG 2
A Got a Small Dent? Here' s what I did! Restoration & Tools 9
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
C MGB Rubber Bumper cover removal MG 5
kodpkd Antenna Removal Austin Healey 9
B General MG Crankshaft Nut Removal MG 4
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
W BN1 Steering Box Removal Austin Healey 11
S TR2/3/3A engine removal Triumph 12
S TR2/3/3A Steering wheel removal. Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
C MGA Dash removal MG 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
R TR2/3/3A Steering wheel hub removal Triumph 11
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
D Heater knob removal Spridgets 6
S 1275 oil pan removal Spridgets 30
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
E austin van heater removal Other British Cars 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
nevets Water Pump Removal Austin Healey 6
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
F Interior Door Handle Removal Austin Healey 2
Z Front Springs Removal Austin Healey 3
R Oil Filter Removal Austin Healey 1
C MGA R/H tail lamp removal on a 1962 MG 5
K TR2/3/3A Removal of tie rod end? Triumph 7
J Ignition Key Cylinder Removal Austin Healey 3
J Planetary Gear Removal Austin Healey 3
Walter74 Adjustable steering wheel removal Austin Healey 4
E MGB 1965 mgb fuel pump removal MG 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
T BJ8 Drain Channel Removal Austin Healey 2
D TR2/3/3A Facia removal steps Triumph 3
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
pkmh Front Spring Removal For BJ8 Austin Healey 8
