Toyota 5-speed bell housing drain hole
Lin
I apologize but I have tried to search for this with no luck. I think, not too long ago, someone posted about drilling a hole in the bottom of the Smitty bell housing similar to what was done on our original gearboxes to allow oil to drain. I am looking for some information on the best place to drill that hole. Perhaps I have the wrong Forum/email list, not sure. Can anyone here help me with what I am looking for?
Thanks,
Lin
steveg
Lin,
I actually drilled an approximately 1/8" hole at bottom center in the flange of the bell housing, right against the rear engine plate.
I wasn't too concerned about the Toyota trans leaking but wanted to know if my engine rear seal installation was leaking.
roscoe
I just receieved a 5 speed kit. I would imagine that with no gasket between the bell housing and the mount plate, that you will know if either your rear crank seal or trans. input seal are leaking without a hole . A hole in the low spot can't hurt and you might see any leaks sooner than you would without a hole. I suspect the original bell housing had a hole because they knew it would leak and might leak fast enough to fill up the housing so as to hit the lip of the flywheel, clutch housing and disk. ZZZZZZZZ, slip, slip :fat:
red57
I don't remember why but for some reason I didn't want to drill a hole when I installed mine 20 years ago. I filed a couple of 1/2 circle grooves with a rat tail file in the bottom of the flange/engine plate joint. I too, wanted to know if the rear engine seal was doing it's job.
Dave
Lin
Lin
Thanks guys! Dave, since you obviously have your gearbox out of the car, if convenient, could you measure the thickness of the bellhousing flange where you have your filed holes? If I drill a hole (the gearbox is in the car) I would like to know in advance how far I need to go.
Thank you!!!
Lin
red57
Lin,
The flange on mine is just over 1/2" thick (.510) front to rear and vertically (between the two grooves I filed) it's 1.210".
BTW, in my picture you can see a horizontal line running part way across the flange about half way up - that marks the edge of my OEM steel rear engine plate (bellhousing flange hangs quite a bit below the engine plate) and it measures about .630 from that line to the top of my drain grooves
I don't know how consistent these are but I bought kit from Smitty in about 1996-7 and I don't know if any refinements/revisions have happened since then.
Need more, let me know.
Dave
Lin
Lin
Thank you, Dave.
I guess I will drill a 1/8” hole about a 1/4” in from the edge of the flange and will expect to go about 1 1/4” deep. Do you think it best to go through the flange as Steve did as opposed to moving rearward a bit? Where is the low point where oil would settle?
Lin
steveg
Thank you, Dave.
Lin
Lin,
I just placed the drill against the steel engine plate and drilled up through the edge of the aluminum flange. The resulting hole will look like Dave's grooves. On second thought, it's probably 3/16".
red57
Lin, The low point is at the flange to engine plate joint (see pic) - it's minor but there is a definite downward slope towards the front in the bottom of the bellhousing. I think that's why I went for the grooves originally (although it's been over 20 years and my memory isn't what is once was :smile:). I think I would do just what Steve did and then you would be assured of hitting the low point - in fact it would have been a lot easier than filing grooves .
Dave
Lin
Lin
Just to close the loop, I did drill the 3/16” hole. At first I was concerned because when I “broke through” the oil started dripping but after a couple of minutes nothing was coming out. What came out had accumulated for the last ten years, albeit light use. So, I figure nothing unusual here. I have a drip pan installed so I will be able to monitor oil seepage. Thanks.
dougie
Nice Epoxy Flaked floor Lin, I expected nothing less. :friendly_wink:
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
Michael Oritt Toyota 5-speed Problem Austin Healey 28
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
M Toyota 5 speed Shifter Austin Healey 2
M synthetic fluid in a toyota 5 speed? Triumph 20
prb51 Tr Toyota 5 speed upgrade Triumph 24
Bob McElwee Toyota 5 Speed Conversion Questions Austin Healey 10
gsalt57tr3 TR2/3/3A 5 speed Toyota transmissions in a TR3 Triumph 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR6 Toyota Transmission conversion Triumph 8
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
S '81 Toyota Celica Other Cars 8
aeronca65t One less Toyota 2000 GT Other Cars 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
4 Another Toyota Twink Spridgets 13
tinman58 Toyota trans noise Triumph 9
PatGalvin TR2/3/3A Toyota Brake Conversion on a TR3A Triumph 5
PatGalvin Routing brake lines for Toyota 4 pot conversion Triumph 5
T TR4/4A Toyota calipers for a TR4A Triumph 18
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
prb51 Toyota tranny users-Speedo Triumph 15
