Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Spec needed for correct ride height
  1. #21
    Join Date
    Jul 2020
    Location
    Fernley,NV
    Posts
    102
    Blog Entries
    2
    Thanks Thanks Given
    Thanks Thanks Received
    2
    Thanked in
    Re: Spec needed for correct ride height
    My wife and I do a lot of road trips in the TR6 it is our road car Canada to Mexico most western states Nat. Parks etc. And most hours top down so we do not talk much. I guess our longest trip was about 2,500 miles but we did two car show in the same month so add another 1,500 mile to Sothern California so 4,000 month. Madflyer
  2. #22
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,656
    Thanks Thanks Given
    35
    Thanked in
    My '71 TR6 did not have door pulls and the panel was pulling away from the door so I drilled a small hole in the top and installed a screw and trim washer to hold the panel when I pulled the door shut. I also (finally) had an electric motor installed on the cellar door and installed a 4-bulb LED fixture to replace the 2 lamp fluorescent that took 5 tries to get it to light. My back was not allowing me to pull open the cellar Cellar LEDs.jpgTR6 panel screw.jpgdoor.
  3. #23
    Jedi Hopeful Foura's Avatar
    Join Date
    Nov 2011
    Location
    Melbourne Australia
    Posts
    144
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by steveg View Post
    Hi all,
    My new TR6 has Good Parts springs all around and I'd like to shim it back to more of a standard ride height. Need a stock ride height (185-15 tires) F & R in order to buy the correct shims.
    Good Parts uses the distance from the wheel center to the fender arch.
    Thank you in advance.
    Steve, you originally asked for the measurement from the wheel centre to the wheel arch. Mine is 380mm front and rear (which is 14.96” in American). Figures for windscreen or soft top heights won’t be much use as they vary with tire size and spring condition. I originally had 185/80x15 Michelin XAS on the car. I replaced them with Hankook Optimo in the same size but I believe that they are slightly larger than the Michelin’s. I also run 195/65x15 Michelins on the car which have the same radius as the original 165x15 that the car had when new. They lower the car by about 1”. The 185s have a 7% greater rolling radius which is roughly the equivalent of going from the standard 3.7 diff to a 3.45 TR6 diff. Good for long trips!
    The measurement from ground to wheel arch on my car is 28”. This is the same as mentioned in the very good suspension article on the Buckeye’s Triumph TR6 web site. Like Malbaby, I still think that there is something else odd about your car. One possibility at the rear is that your suspension brackets are wrongly installed but the front is way too low. Do you have any other TR6s in your neighbourhood that you could look at? Look forward to further reports.
    Rocky
    67 Triumph TR4A
    95 Holden Commodore 355 V8 (The Rocket)
    09 Peugeot 407 V6 Diesel Coupe
  4. The Following User Says Thank You to Foura For This Useful Post:
    steveg  (08-08-2020)
  5. #24
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,264
    Thanks Thanks Given
    178
    206
    Thanked in
    Rocky,
    Measured one side: front 26-1/8"; rear 26-5/8". Ft wheel center to arch: 13-1/2".
    Just got my 1/2" spacers and will install them hopefully this week and report back.
    I also noticed my car has a lot of shims for the lower front A-arms.
    After I deal with the ride height via spacers, will address the rear swing arms with adjustable brackets if necessary.
    Baby steps...
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    1959 BN6 / 1974 TR6
    http://www.pbase.com/stevegerow
  6. #25
    Join Date
    Oct 2014
    Location
    australia
    Posts
    445
    Thanks Thanks Given
    3
    Thanked in
    13.5" is very low. Would be good for a track car with shortened and uprated springs
    1/2" spacer should give you an extra 1" in height.
    Your springs are either super soft or have been cut.
  7. #26
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,264
    Thanks Thanks Given
    178
    206
    Thanked in
    Quote Originally Posted by malbaby View Post
    We'll see. When I get them out to install the spacers, will photograph, measure and compare to the specs on Good Parts' website. Will followup when I have more into. Am not averse to getting thicker spacers if necessary.
    FWIW - the ride is good - no bottoming, which I assume would be a problem with too-soft springs. Compared to my Healey, the TR6 is a comfortable ride indeed.
    Steve Gerow
    Altadena, CA, USA
    1959 BN6 / 1974 TR6
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
