Page 4 of 4 FirstFirst 1234
Results 61 to 63 of 63
Thread: HD8 carb on Healey 3000
  1. #61
    Join Date
    May 2013
    Location
    Purley, England, UK
    Posts
    54
    Thanks Thanks Given
    Thanks Thanks Received
    4
    Thanked in
    Re: HD8 carb on Healey 3000
    Maybe you are right ? But let’s wait for Lin to compress them as per Richards instructions, to see if he gets the same answer for each spring. I have three sets of springs, two old Blue/black and one new Red/green. The only difference is the spring thickness. They are all the same length. So, why are Lin’s new one a different spec of length and thickness.
    It maybe a different manufacturer that Burlen are not disclosing ?
  2. #62
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,357
    Thanks Thanks Given
    194
    214
    Thanked in
    FWIW,
    Hammill, pp53-54 states that it is most important that the springs have equal ratings by the scale & height method. Worn but equal springs are OK. He also states that weaker springs will give higher performance as long as the low & mid-range of the needle compensates.
    From Burlen catalogue, p50:
    AUC4826 11.25oz @ 3.875"
    AUC2107 4.5oz @ 3.875"
    Interestingly, for the competition tricarb HD8, Burlen specs the normal UH needle and the 2107 spring.
    Steve Gerow
    Altadena, CA, USA
    1959 AH BN6 2-seat roadster / 1974 TR6 Emerald Green
    Check out my galleries:
    http://www.pbase.com/stevegerow
  3. #63
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,736
    Thanks Thanks Given
    14
    Thanked in
    That is a good thought too AWD274 .
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
