Water Pump ?
George Zeck
Hello All:
My car has been ignored for a long time (2 tanks of gas in 4 years). I've sucked that out and have all new stuff. We went for a long drive (90 minutes) each way and the car handled nicely. Got home and saw coolant on the ground the next day. It appears to be 100% coolant and not mixed at all with oil.
To me (& my semi-educated opinion): Water pump has gone bad. Nothing coming from it (exterior) but assuming blades have broken internally allowing the leak. Nothing significant came out until I opened the radiator cap then out it came:
https://photos.app.goo.gl/GgWHHfYUqz8CwPXv6
Any reason I should suspect something different that the water pump? I had a 'racing water pump' on there from (Winner's Circle) when I last did this in 2002-ish. I'm about to order a replacement / hoses / therm.
Lastly - do I have to remove the radiator / oil cooler to perform this task? Hoping to get lucky, but why now. I do have the option to take it somewhere, which I am really debating.
Thank you all-
George
** 1970 1275 engine **
1964 AH Sprite MK II
zabond
if you cant see a leak from the pump you may have a bad radiator cap that is not holding pressure and allowing coolant to escape via the radiator overflow pipe, broken/worn pump vanes wont cause a leak via the pump body, only cause overheating, first step is to determine where the leak is coming from if at all or just an over full radiator [I know if I fill my radiator to the top it dumps about a cup full out the overflow after a drive, if I don't top it up again its happy at that level] to replace the pump you are best removing the radiator unless you want to work in a very restrictive upside down awkward position ;)
Russ
Bob Claffie
Look for moisture at the "weep" hole in the waterpump. That's where you will find fluid if it's a bad seal. I agree with the above comments on the unlikely cause of a leak to be damaged pump vanes
JPSmit
I have from time to time had my car burp coolant - never exactly figured out where it was coming from - but it didn't seem to affect anything.
Did also have a pinhole in a hose that only manifested itself when the car was running and hot and under pressure.
Madflyer
All the above is right on. Water pump would only leak from seal. If your overflow tube does not go to a can jar what ever toping off rad will push some out at running temp. I would change the rad cap first. Squeeze hose next if cracked replace same top easy lower not so much. Is the fluid good adding water will change it's ability to cool at pressure your rad cap should be 8 to 12 pounds. Do this test; from cold with cap off start motor you should not see water moving in rad until thermostat opens. ounce open you will get some steam and much water flow at rad. Your water pump will not move water even with motor at any RPM until thermostat is opened if it does either the thermostat has been removed or stuck open. The purpose of the thermostat warm water in the block and open to rad to cool water normal temp should be 165deg to 185deg Three steps Check rad cap Check hose Change fluid add tank to over flow tub. And drive your car more OH fall color is the best time and you will need a heater to keep you warm .
Madflyer
Jim_Gruber
And the radiator cap is not available at FLAPS. Needs to be a deeper Radiator Cap assuming you are running an OEM Radiator.
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
Got_All_4 TR2/3/3A Water pump problem Triumph 7
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
matmire Replacement Water pump issue Spridgets 5
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
Got_All_4 TR2/3/3A Water pump dissasembly Triumph 10
L Trouble refitting pulley to new water pump Spridgets 9
JFS TR2/3/3A Bad Water Pump Triumph 11
tomshobby replacing water pump Spridgets 1
