Fitting a 100-Six grille.
DerekJ
Many moons ago I removed the original grille and replaced it with a wire mesh, probably for looks but also saved a bit of weight. I was contemplating re-fitting it and took a look at what might be required. I guess the top three tabs on the grille attach to the same bolts that hold the eyelid piece of trim. Is that correct?
My problem is the what do the bottom three tabs of the grille attach to. Looking at the bottom of my shroud there seems to nothing that I could attach the grille to. About 5 years ago I had a couple of offs which re-arranged the shroud and it needed a lot panel beating to get it to where it is now, maybe the fittings disappeared during that work. I had the wire mesh at the time so it wasn’t an issue.
So question is, what do the bottom three grille tabs actually bolt on to?
John Turney
There are supposed to be three tabs on the bottom. Mine are pop riveted to the edge of the bottom of the opening and the chrome trim strip covers the rivet heads.
Keoke
MY BJ8's have three tabs at the bottom that require three nuts bolts and washers to secure the grill. ??
healeyblue
Heres a pic where you can see the holes where the steel brackets are riveted to.
steveg
My car's in the body shop right now and am dealing with this. The three tabs on the bottom are held on by tiny flathead countersunk rivets. Wish I had a pic, but car is, alas, still in the shop (7 months now).
IIRC the upper 3 bolt through to captive nuts in the grille eyebrow. All grille fastenings are 1/4-28 bolts.
DerekJ
DerekJ
Thanks guys, I obviously no longer have the three tabs and the holes have been welded up. I think the crash caused some splits around a couple of the holes and they were filled. It seems odd that all three of these tabs have disappeared although I can’t recall if all three were present back then or even what they look like! Looks like I’ll stick with mesh for a while longer:smile:
red57
Kilmartin makes kits containing all 3 brackets - part numbers: AH369A for BN4-3000mk1, or AH369B for 3000mkII-BJ8.
Dave
GregW
Platinum
Hi Derek,
Could you mount the grill with the upper 3 mounts and position the lower tabs onto the grill to locate where to drill new holes?
S Spitfire Cyl head coolant hose fitting Triumph 1
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Writer2022 GT6 K+N Filter Fitting Triumph 2
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
A Making an A-series engine stand adaptor fitting Spridgets 2
D TR2/3/3A Windshield frame fitting. Triumph 2
B Fitting the Boot Lid Seal Austin Healey 8
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
edkap2002 TR6 lower radiator hose fitting Triumph 2
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
R TR2/3/3A Fitting windshield Triumph 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
D TR2/3/3A front Apron fitting Triumph 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
ckeithjordan TR2/3/3A Oil Fiter Fitting Frustrations Triumph 13
M Fitting a modern radio Austin Healey 9
TulsaFred Convertible Top Fitting problems Spridgets 29
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
TulsaFred Carpet fitting in the Bugeye Spridgets 3
KVH TR4/4A Fitting New Dash--Problem with Dash Pads Triumph 3
PeterK TR4/4A Fitting TWM manifolds for DCOEs Triumph 2
Patrick67BJ8 Poor Fitting New BJ8 Glass Austin Healey 9
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
I Bugeye fuel fitting Spridgets 3
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
H TR2/3/3A Sway bar fitting Triumph 7
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
P Good fitting car cover recommendation? Austin Healey 9
2 TR2/3/3A Fitting mirror against new windscreen Triumph 5
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
DornTRoriginal TR2/3/3A Stone Guard and Fender Fitting Issues Triumph 6
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
