TR6 HD6 carbs on TR6?
Jerry
Not on a TR6 but I have HD6 on my TR3. Had to buy lean needles but I got more power from the engine. Another guy in our club that also has a TR3, remarked on how much more power my car has. It can keep up with Healeys. I did install a cable to work the throttle since the controls are different. While the 4 vs 6 cylinder Triumph engines are different, the HP that comes out is not that far apart.
steveg
steveg
Jerry - thank you for the input. Good to hear from someone who's actually done it. Can you post a picture?
Was interested in this, as I already own two HD6s left over after I upgraded my Healey to HD8s and was thinking of rebuilding them and installing on the TR6 as a fun project. Joe Curto thought it was a bad idea as by the time I bought vertical float bowls and had him rebuild them, I'd be in the $700+ range - half the price of Moss' new HS6 kit. But I can rebuild them for a lot less than $700.
Not sure why they'd put out any more power as both designs have the same 1-3/4" bore. Are you sure your car doesn't have other advantages vs your buddy's? Apples-to-apples and all that rot.
The main advantage is HD-type carbs are easier to tune, as the screwdriver-accessible mixture screw is accessed from the top with the air cleaners in place.
Jerry
My understanding is the HD6 have an accelerator pump that may be the difference. My engine does have some head work that would help also.
steveg
steveg
SUs don't use accelerator pumps. The accelerator function is a combination of the strength of the piston spring and the weight of the damper oil. This is one of the reasons they aren't quite as good as Webers, which have an actual accelerator pump.
glemon
I put older Zenith Strombergs from a TR4 or 4A on my TR250. They are much simpler carbs, not really any different than the same era SU other than the rubber diaphragm to seal in the vacuum. Not suggesting they are better than HD6s, but another option. They are not stock of course, but they do look closer to the stock item than SUs.
titanic
I used the same carbs on my TR6 without any problems. The only downside was not having ports for the crankcase vent tubes and also having float chambers that required removing the carbs to deal with a stuck/clogged needle valve. I switched SU HS6 carbs that had the vent tubes and have been satisfied. The SUs did require modifying a stock needle profile to suit the engine.
Berry
steveg
steveg
...The SUs did require modifying a stock needle profile to suit the engine.
Berry
Berry - modifying needle profiles is non-trivial. Are you running O2 meters?
I had planned on starting with the Healey lean needle on my HD6s, but might be better off using whatever needle the Moss HS6 kit comes with.
pdplot
Just an idle question - why would you bother? The two carbs are very similar - just the rubber skirt on the Strombergs so Triumph wouldn't have to pay royalties to SU.
titanic
Steve-I did use an AF meter, but it was a long time ago and the only thing available was the narrow band type, which was better than nothing, but not much. Later, a good Samaritan (Dale O) who had a wide band AF meter, and had similar engine mods, shared his experience He recommended a KN needle with 4-1/2 oz red springs for "everyday use". He re-profiled it for a "performance" needle If you are interested, PM me and I will give you the profile.
I think Moss recommends BAG or BAE (depending on mods) with the 8oz yellow springs, i found them to be too lean.
If you are considering engine upgrades for performance, an increase in the CR to 9.5, recurving the dist., and then maybe an upgrade in cam, gives the most bang for the buck.
Berry
steveg
steveg
it was about smog. The SUs couldn't cut it.
Why would I bother? Good question. Maybe I won't - having fun thinking about it. :fat:
jfarris For Sale Air Horns for SU HD6 Carbs Triumph Classifieds 4
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
B Adjusting SU-HD6 Carbs Austin Healey 2
N HD6 / 8 carbs. Austin Healey 13
J What are HD6 carbs worth? Austin Healey 0
S Leaking HD6 Rear Carb Austin Healey 10
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
Lin HD6 1-1/2" SU Front [L/H] Float Chamber Austin Healey 1
F How to restore screws, springs and fixings on SU HD6 Carburetors? Austin Healey 7
J SU HD6 - Slow Idle Screw Austin Healey 13
C HD6 Carburetor Spacer Blocks Austin Healey 4
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
B SU-HD6 Gas Leaks Austin Healey 6
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
BOBBYR HD6 CARBURATORS????? Austin Healey 3
I Setting up / Tuning an HD6 Carb Austin Healey 3
red57 Fitting 3 HD6 to 6 cy Healey Austin Healey 10
DerekJ Triple 3/4" SU's HD6 Austin Healey 12
G HD6 Question - on TR6 Austin Healey 4
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
