MGB strange??
cowboy79
1973 mgb bought for 800$ from original owner sat 5 years transmission problem car would not shift and would drive if started in gear changed slave cylinder tried to bleed clutch now transmission shifts smoothly and car wont move wth???:rapture:
LarryK
Does the engine rev up when trying to move? Do you have full movement from clutch pedal? Does it feel like the clutch may not be engaged, as in push rod adjustment wrong? Lots of varibles.
bob67bgt
If you did not change the hose there could be pressure still in the slave cylinder. Crack the bleed screw and see if the fork moves. Your foot pressure can move fluid thru the hose but it may not release. If that's the case a few pumps and you will blow the piston out of the cylinder.
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
jlaird MGB Strange daily question. MG 10
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
Musicman Strange Clicky/Tappy Sound Triumph 6
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
racingenglishcars This is a strange one! Spridgets 9
angelfj1 I noticed something strange FORUM Navigation Questions 4
