Speedo drive gear
4tecdog
Anyone know if there is a Speedo drive gear available that would give a more accurate reading for a 19/41 ratio diff on a sprite. The std one looks quite expensive from some suppliers so it would be good to get one that does the job more accurately.
Jim_Gruber
Speedhut GPS Speedo. Dead nuts accurate. Works with my 5 speed. Bugeye Guy even sells one with a pretty good imitation of the OEM Smiths Speedo. Mine I created my own faceplate design power and ground and little GPS Magnetic antenna site on the dashboard where it can see the sky. As I was going to a 5 speed i bought a matching Tach. so that's two less cable drive products that I don't have to buy Adapter boxes for at $150+ a pop every other year.
4tecdog
4tecdog
Hi Jim thanks for your suggestion I have looked at these and they would be the perfect answer however I run a rally trip meter that takes its pulse from the sender unit spliced into the Speedo cable and that instrument can be accurately calibrated so I would like to keep a cable drive. Also Im not sure if Gps speedometers are approved in the UK to pass the Mot? They really look good though.
HealeyRick
41 divided by 19 gives. 2.16???
4tecdog
4tecdog
Should have said 9 not 19 must be an age thing! That equates to 1 to 4.55 previous diff I had was 3.7 and the Speedo was fairly accurate with that.
4tecdog
4tecdog
Thanks we have guys who can recalibrate the Speedo here in South Wales, Are you saying there is only one drive gear ? I was hoping to get closer to the correct reading with a different drive gear don’t want to recalibrate the gauge as I may put the original diff back in for cruising. Set up for hill climbs at the moment.
HealeyRick
Speedo calibration is done in the speedometer head, not via the transmission gear. All the transmission speedometer drive gears are the same. You'd need to change the gearing in the head to recalibrate. This explains the process: http://www.lotus-europa.com/manuals/misc/electrical/Smith-jaeger_speedo_repair.pdf If you wanted it to be "close enough for government work" you could time your car through a measured mile at what feels like 60 mph and determine if the speedo is reading high or low, prise off the speedo needle and replace it so it reads accurately at 60 and you'd be kind of accurate.
4tecdog
4tecdog
Much clearer now HealeyRick thanks for the article very informative. I obviously got the wrong end of the stick when I heard you could change the gearing they meant in the Speedo not the gearbox. Think I will go down the recalibration route.
Pythias
There ARE different drive gears available.(at least for the DATSUN tranny) Paul A. had someone in Portland Oregon (a speedometer shop I believe, but can't recall the name) he had them custom made depending upon which diffy and the size of tire one one going to run. ...
That said, I had changed the diffy from when I had the tranny changed. At that point the error in speed was different than the error in the odometer. One was at 15% and the other at almost 20%. ...
I like Mr. Gruber have changed to the Speedhut gauges for both tach and speedo. I liked the style from Bugeyeguy so I went that way. And I LOVE
THEM. No more bouncy speed. No more speed error. accurate tach that doesn't change reported rpm depending upon ambient temperature. I also had installed the programmable fuel gauge. Now ALL my instruments function properly!
Boink
Bronze
Hi Bill:
Yes, there used to a "Speedometer Repair" in the Pearl District but it's no longer there. There is a company by the same name elsewhere (and I don't know if it's the same guys). I once had them repair a speedo on a '62 Mini. Thankfully, when I sort of inherited a complete Datsun conversion with 3.9 diff (Paul's conversion), the matching gear-drive (an elbow) and speedo were perfect.
Going to ABFM this year? I'll be there.
Pythias
I just registered yesterday. It will be my "reveal". Over the past couple of years I have
Had ALL the rust taken out and the car repainted. I also took off the front bumper and had the holes filled. Never a front bumper again. (2018)
Had the interior completely redone-- door cards, carpet, all panels replaced. Had the front end rebuilt/replaced and installed poly-bushings all around. (2019)
Had the dash repainted (crinkle finish) and as mentioned above replaced the instruments (except the dual gauge). (2020)
Converted to negative ground and installed a genernator. This also required replacement of the CRANE electronic ignition which was + ground only with a newer FAST version.
It is now a "no excuses" car. ... Well, I still need to have the rear bumper re-chromed... .... .... ......
Boink
Bronze
Wow! And here you wanted to sell it a few years ago. Now it's surely a serious keeper.
I wonder if ABFM attendance will be way down this year (others think so - probably few out-of-towners). A better chance to win something. I'll help stuff the Sprite ballot box for you. :eek:
Pythias
I had decided that if I couldn't sell it, I could at least give it it's due. When I see you I'll tell you what I've put into it. I for sure can't sell if for that.
Jim_Gruber
Bill I’m with you, when investment exceeded $20k I stopped keeping track. Now it just a fun toy with all of the goodies. Will I get money back if and when I sell it. I hope tgat day is a long way away but I do change decades in a few weeks. Tempus Fugit! I realize I bought my ‘68 Sprite back in ‘98 or ‘99. Bugsy IV I’ve owned for 4 or 5 years now. And he’s still not done. Dashboard hopefully gets hung this weekend.
nomad
I'm sure there are different speedo right angle drive boxes for the Sprite for different ratio differential's. Just don't know where to find them. Google some of the speedo repair folks. Nisonger, Palo Alto and others.
Kurt
Rut MGB OD install, speedo drive gear MG 0
Q TR2/3/3A Speedo Gear Drive On Tr3 Overdrive? Triumph 0
ekamm TR2/3/3A Tr3 speedo drive gear needed Triumph 0
M Speedo Drive Gear MG 3
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
B TR2/3/3A Gearbox speedo drive seal Triumph 1
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Gerry M TR6 Speedo Angle Drive Triumph 2
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
Gerry M TR6 Speedo Angle Drive Triumph 9
glemon Speedo Angle Drive Triumph 6
L Speedo drive [repeat subject] Austin Healey 7
M Speedo Angle Drive Austin Healey 5
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
M Speedo angle drive MG 3
B Late O/D speedo drive question MG 0
Tinkerman Speedo Drive new picture still ????????????????? Triumph 2
B MGB 72 mgb speedo drive seized.....easy fix? MG 11
DNK Speedo Drive Pinion Triumph 14
SwamperCa Speedo angle drive MG 8
DrEntropy Speedo drive progress report, Julian? MG 34
angelfj1 Right-Angle Speedo Drive Triumph 6
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
N Speedo identification? Other British Cars 4
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
Patrick67BJ8 Speedo calibration Austin Healey 22
