Installing AC in my 1960 Healey
Factoryman2000
Hi, Recently visited a local restoration shop and saw AC install on an MG. What surprised me was that the single crank pulley was left in place and the new compressor had a dual pulley, so that the v belt that used to drive the generator( alternator in this case) drove the compressor. The second pulley on the compressor now powered the slightly relocated alternator. I watched this system run and it all seemed reliable. The shop told me that new rotary compressors require little effort and it eliminates the need to create/fabricate a dual pulley on the crank shaft. Any opinions? Advice? Experiences you can offer me. Not having to go the traditional dual pulley route would make the install of AC a simple process for me.
Anton
HealeyRick
F
Factoryman2000
Thanks for the reply. He info does list all required elements and that is a big help. I see your comments often on BAT, you must really keep busy attending to all these chores, amazing!
Administrator
Boss
Since this is a specific Healey technical question, I'm moving this thread to the Austin Healey form but leaving a "pointer" to it in the "New Member Introduction" forum for 1 week. If you are reading this you w ain the Austin Healey forum. Please another in the "New Member Introductions forum also doc re yourself to the other forum members.
Jerry
I installed a vintage air unit in my Austin Healey. It will cool from your legs down. There are no air vents blowing at your upper body. Not really space to put them. The unit works but I would say is not successful. When it turns on, the idle drops to almost a stall. If we come to a stop sign, my wife turns it off, and back on after moving again. we don't have a computer to up the idle as in a modern car. The heater unit is actually better than the original though!
Jerry
F
Factoryman2000
Jerry, Thanks so much. The unit you installed is below the dash where the heater box was located? IE the aftermarket style under dash unit.
Your compressor is the rotary type? Did you add a crank pulley or has the compressor two sheaves? Thanks Tony
John Turney
I have AC in mine, I installed it in 2018. If you buy the compressor from Vintage Air, it will have two sheaves.
John Turney
Jerry
You need an idle adjustment solenoid that cracks the throttles open when the compressor kicks in. It's what they used before computers.
Jerry
Two pulleys on the compressor and the unit replaces the original Healey heater. Solenoid for the idle adjustment? give me some more hints or a link on that. I can learn new things!
Jerry
John Turney
Good to know, Patrick. I attached a Holley 46-74 Throttle Solenoid to a self-made bracket acting on a lever attached to the right-hand side of the throttle cross-rod.
John Turney
Jerry
I've been trying to prepare a description and parts list to upload, but Basil has some strict limits that I haven't been able to overcome. If you PM me with an email address, I can send to you, or, if you're a member of AHCA, there are some back issues of Healey Marque with some articles:
  • July 2009
  • November 2009
  • February 2010
  • January 2014
  • September 2015
Patrick67BJ8
This is a drawing of what I have. It does use a Holley solenoid.
vette
Anton, The configuration of running one belt driven component from another belt driven component is not that unusual in the aftermarket custom and hot rod circles. It is something that always makes me take a step back and a second look when I see it but it is not that uncommon. Since it has become an acceptable practice I have to believe it is reliable. Some of the street rod configurations don't give much room for multi-groove crank pulleys.
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
Tinkerman TR2/3/3A Installing small body stone guard Triumph 9
