Clicking from rear
Upland
I have a new clicking sound from left rear it increases with speed and stops when I apply light brake pressure, and starts up as soon as I release the brake pressure. It keeps pace with speed and is a clear, metalic click. I have new rear drums, pads and cylinders, and have pulled both drums and all seems well. Are we talking about wheel bearings, and if so how do I proceed.
Thanks for any suggestions.
UPLAND
JPSmit
sounds more like something is touching every rotation - seems like something connected to the brake shoe or the shoes themselves. A bearing wouldn't click and it would keep making a noise even if the brakes were applied.
Is it possible to see if something is suddenly shiny?
Jack it up and rotate the rear wheel and listen if it is still there. If it is take off the wheel and see if it is still there, then rotate the hub and see and finally take of the hub. should help with diagnosis.
good luck!
Jim_Gruber
Check and make sure your drums aren’t rubbing their edges. Rotating slowly with rear brakes adjusted correctly make sure the drum is not rubbing an edge. If so a light touch with an angle grinder on the outer edge will fix. Yes it could be a wheel bearing Timken 207FF Sealed Bearings that fit a Subaru we’re a direct replacement that dropped in to my BE.
another thougt, with car up on jackstands and properly blocked up, have someone bring the car up to speed and double check you don’t have a bad tire that is vibrating out of round etc. could just be a tire issue.
Upland
Upland
Well, jacked up the back, spun the tires, removed the drums, spun the axle. No rub spots, could not duplicate the clicking. Took it out for a spin, applied the ebrake, clicking continued, tapped the brake pedal clicking stopped, brake off, clicking back. Coasting in neutral, clicking continued. Jacked up front, spun wheels, removed wheels spun hubs. Could not reproduce clicking. No rub spots.
JPSmit
could it be something around the clevis pin on the brake pedal? They have a habit of the hole becoming an oval? could there be something rattling there?
Madflyer
Minilites balance weight on rim unless glue on rim were used. How about something next to drive line. Madflyer
Jim_Gruber
I've got JBW 8 Spoke wheels on my BE but inside rim is real close to the Rear Spring. Is there a mark on the inside of the rim from contacting the Spring.
Madflyer
I had a bad universal in TR 6 half shaft one side. only made noise at slowing down rest of the time was in a load. Braking may be doing the same thing. Madflyer
Upland
Upland
I'll check the u joint, but even the slightest pressure on the front brakes stops it. Pressure on the rear brakes through the ebrake does nothing.
Jim_Gruber
So that might point back to the front brakes, check caliper bolts, pad rattling or not retracting and it's rubbing on the rotor, warped rotor, worn pads and you are hearing the warning tickler.
Carlbanan56 MGB Rear wheelbearing clicking MG 8
C Clicking in Right Rear of 1500 Triumph 5
S Spitfire Differential clicking Triumph 6
M TR6 Clicking sound when accelerating Triumph 11
KVH TR4/4A TR4--Clicking Like Tappets Triumph 16
S TR6 TR6 Starter/solenoid Clicking Triumph 1
R Transmission Clicking Triumph 9
regularman heard a clicking sound and found the cause Spridgets 6
G FUEL PUMP WON'T STOP CLICKING Austin Healey 12
M T-Series Clutch clicking/tinging when engaged MG 5
doughairfield Clicking sounds Triumph 43
R Clicking noise when applying brakes Austin Healey 4
Dadandson My U Joints are clicking away Spridgets 14
BoneIdle Clicking in reverse MG 1
W valves clicking...i think - need advice Triumph 11
78MGB Fuel Pump Will NOT Stop Clicking!!!! MG 20
S slight clicking/tapping noise after a head rebuild Spridgets 4
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
