TR2/3/3A Rookie mistake,
So, what I’ve learned so far, is that before lifting the car off the ground, FIRST, remove the front suspension snubbers. Speaking with Yoda John, he told me this AFTER, I had the car on jack stands with the wheels removed.
He told me, once the weight is off the suspension you will not be able to get to the lower shock mounts to remove the shocks. With the shocks installed you can’t remove the coil springs to begin your front suspension work.
This became obvious ONLY when I tried to compress the springs with a pry bar for leverage, the front of the frame would lift up off the jack stand. After a lot of head scratching I came up with a plan. A bit of weight provided by my F150 and the application of the pry bar, I was then able to compress the springs enough to get to the snubber AND shock bolts off. Now the pieces of the CUT UP shock came tumbling out to lower control arm hole.
Now I’m in the market for a coil spring compressor so I can remove the springs. Harbor Freight, here I come.
I’d like to thank John for his suggestions to cut out the shock, and his guidance in this endeavor!
Here are a few pictures for your amusement.
Sweating it out in TX, Joe
9087894E-353C-4273-A46E-640ED31CF15C.jpeg53F17DBC-DF64-4769-BA2C-4B17C2F1D3F7.jpeg84E3EC89-9D6C-495B-8B47-2C18189629FD.jpeg
DavidApp
I had the opposite problem. Fitting the snubbers on the front suspension with no body or engine for weight to compress against. Do not remember exactly how I did it but it was a battle.
David
Sarastro
If you find a commercial spring compressor that fits a TR, please let us know. I've never found one.
I've used a length of 1/2" threaded rod with plates on either end. It fits into the spring where the shock once was. Cheap and effective.
By the way, that problem--where you need weight on the suspension either to install or remove parts--is pretty common in all kinds of cars.
Frank Canale
I too made the same rookie mistake but I removed my engine and transmission. John also help me recommending replace motor and transmission. Wise decision. Easier and safer than fighting the coil spring. I made my spring compressor from all thread and plates. Added handles to nut similar to Churchill tool. Frank
mrv8q
Back in the day I bought a spring compressor from TRF. Went out to get a part number but the bugs ate the label. ISTR they offered a TR3 and a TR6 version, don’t know if it is still offered.F22CDA0C-DE26-4940-ACDA-88AC5CDDB995.jpg
Looks like it is still offered, RFT102. I have yet to use mine so can’t say how effective it is.
Rhodyspit75
I would not buy the HF compressor. I had one and used it once. I then threw it away. It’s dangerous.
Busted knuckles
Thanks for all the input on this guys. I did this job on a Ford Galaxie several years back and it was then that I realized how dangerous a compressed coil spring can be. In fact there is a YouTube video of a coil spring cutting loose from a auto repair shop. It sounds like a bullet shooting across the street, would definitely kill if you got in the way.
With that my friend, John is bringing his spring compressor over tomorrow, “NOT a Harbor Freight tool”, and I hope to remove the spring with little to no threat.
Moving on, Has anyone done the Toyota 5 speed transmission transplant to a TR-3A
I’m considering it and I have a good lead on a donor W55 transmission.
This is getting a fer bit out ahead of this project, but was just looking for intel from those who have done this before.
Thanks Y’all.
Joe in TX
mrv8q
Joe in TX
I’ve always thought it is a W58 Supra/Celica gearbox you are looking for?
Busted knuckles
Yes, you are correct. I just looked at MossMotors conversion kit, it does specify W58.
The donor car is a 1985 Celica with 170K on it that does have a W58 installed.
I have not had a close look at it yet, so I’m not sure of the condition of the trans but was just looking for intel on the possibility of doing this.
Thanks for the clarification.
Tybalt
Back in the day I bought a spring compressor from TRF. Went out to get a part number but the bugs ate the label. ISTR they offered a TR3 and a TR6 version, don’t know if it is still offered.View attachment 64406
I haven't used the Roadster's RFT102 but have used the RFT103 on multiple TR4A/250/6 cars. Easy to use, very safe and effective if a bit tedious just from having to run the nut up the threaded rod to compress the spring for installation or to let the spring relax for removal. These tools are available three ways from them:
RFT102 for TR2 through TR4 ~$70
RFT103 for TR4A through TR6 ~$70
RFT104 has plates from both the RFT102 and RFT103 to cover the range from TR2 to TR6 but only one threaded rod ~$90
I would run from whatever they have Harbor Freight and the like, they don't really fit these cars well (the voice of bad experience having bought a set many years ago and trying to use them) and then once I saw how things were looking, I quickly put some fasteners back at the spring pan/lower arm connection points. The thought of all the pent up energy in that spring coming at out at some unknown angle scared me silly. There's not much upside and plenty of potential injury inducing downside when fiddling with suspension springs and ill fitting, unsafe tools.
BTW, since you're in Keller, have you hooked up with Red River Triumph Club? If not, you should consider it. There's probably someone in the club that has one of the spring compressors and just might even be willing to come over and help another club member. Joining up was probably the best thing I did on buying my TR6 when we lived in Fort Worth.
Graham H
I had the same problem as David, getting the shockie back in without the body on the chassis. I used a good concrete bolt in the shed floor, chained the chassis to it and jacked up the suspension one side at a time, a bit ugly but got it done.
Graham
Busted knuckles
Good info, Thanks guys!
While I am a tool junkie, and would love to OWN my own spring compressor, I’m not planning on making this mistake again, there’s plenty of NEW mistakes to make still. ��
I should have a “loaner” compressor here this evening to complete this part of the dismantling.
Tybalt, I have see the Red River Triumph Club license plate brackets around town, I”ll give them looking into.
Well it’s another scorcher in North Texas today, 96* with a heat index of 200*, at least it feels that way, dripping hot!! If yer not done by mid morning, it’s gonna have to wait.
I was able to have my son help me haul the Transmission and read differential to the quarter wash for a good hosing off before the heat really kicked in, so there was some progress.
that is all.
Busted knuckles
C2316D82-C4BF-42F5-A90B-3F755135D6E5.jpeg02923006-0E4A-42BA-A23F-5ACAB075F169.jpegF13AA64B-E065-4370-B541-8EEE2D58C1AD.jpeg158C31F6-608A-4FDE-A51B-5DC491F77247.jpeg
So I’m still having issues with sideways pictures, sorry for the stiff neck.
John loaned me his spring compressor and it worked great. Unfortunately there were no manufacturing markings, other than “Made in USA”, so we know it’s NOT from Harbor Freight.
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
D TR6 TR6 won't turn over -Rookie TR6 owner Triumph 12
T TR6 Rookie photo od TR6 carb cleaning Triumph 2
T TR6 A photo for TR6 rookies taken by a rookie Triumph 16
Popeye Sheet metal question from a rookie Restoration & Tools 5
T The Rookie Scores a Homer! Triumph 8
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
jcb0410 Another rookie Austin Healey 5
B Rookie Jaguar 0
TomMull I posted this in the "other cars" section by mistake Other British Cars 5
dklawson Spitfire My Spitfire Mistake - Advice Needed Re. Head Gaskets Triumph 14
sd80mac7204 Think I made a mistake Triumph 4
wingsandwheels Dumb mistake...nice drive w/ e-brake on Triumph 6
dklawson 20 Year Mistake - Coil Type Triumph 16
F First timers mistake our not. [cam bearings] Spridgets 11
D i made a stupid mistake. best course of action? Triumph 35
J Did I make a big mistake Triumph 18
M I may have made a mistake with the block, Help Triumph 7
tosoutherncars I think I made a typical mistake... Spridgets 5
rlandrum The $640.90 Mistake Triumph 14
soren_ak omg we made a mistake . Austin Healey 16
S Spot the mistake... Spridgets 33
H Have I made a mistake? Car is dying :[ Spridgets 68
trrdster2000 Petrol tank mistake Triumph 1
