TR4/4A Steering U-Joint Question for TR4A
fpstude
I'm replacing the steering u-Joint in our '67 TR4A. When removing the existing U-Joint, I did not pay attention to the details. There are two sizes of holes on each side. Which size hole has the bolt head? Why?
In advance, thanks for the input.
Andy Blackley
Perry:
That rubber donut is also used on the TR6 and a number of other cars built by Triumph. It was modified over time to use a round headed cap screw (Allen head). You can use your old bolts with the addition of a washer under the head of the bolt, or use all new Allen headed bolts such as Moss Part #320-185 which is pre-drilled for the safety wire. A "top tip" is to use a 2" to 3" hose clamp to compress the thing enough to allow you to get all of the bolts lined up. Be sure to include the ground straps.
Here is a link to a good description, showing the later Allen bolts used on the TR6.
http://tr6.danielsonfamily.org/SteeringColumn.htm GroundStrapNew.jpg
Andy Blackley
I just recalled that if you are reusing your old bolts you don' need a washer under the head as I suggested above, merely orient the donut so that the recessed holes are hidden by the adaptor clamp.
fpstude
fpstude
Andy, thanks for the input.
Both TRF and Moss are 2-3 weeks out to supply this part, telling me they both have the same source. I may install the old one.
Andy Blackley
Do you mean the Allen head bolts? When I did this job on my car I used slightly longer bolts bought at the local hardware store. They thread all the way through the clamp and instead of the safety wire I used lock nuts. Given that the rubber donut puts the entire assembly under tension there is no way those bolts are going to back out. I am attaching photos of what I did.
Here is a long thread on the Triumph Experience forum form last year : https://www.triumphexp.com/forum/tr4-and-tr4a-forum.7/steering-coupling.1644775/page-2
fpstude
fpstude
I installed my existing u-joint today. As I saw in the link in Andy's #2 post above, I used a hose clamp to compress the u-joint. It made a lot of difference in the ease of installation.
Actually, the purpose of working on the u-joint was to correct the horn that would not work consistently. I made a new ground cable and cleaned all of the bolt connection. The horn now works with the steering wheel in all positions.
Again, thanks to everyone for the assistance
J Ball joint and steering question Triumph 12
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Keith_M steering rack inner ball joint Spridgets 14
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
