TR6 Keep or Lose the Spare?
Martin Secrest
Just curious. I run my TR6 mostly around town and have never actually had a flat tire in 20 years. Thinking about taking the spare tire out of the trunk to save weight, but I wonder if I would wish I had it in the car if I were rear-ended in an accident. What's our collective wisdom on this, if we have such wisdom?
Gliderman8
I have a space saver spare in my TR6. It’s from a Accura. It has the identical bolt pattern as the TR6. It weighs less and takes up less room. Got it in a salvage yard for $20.
M_Pied_Lourd
Yeah, a more modern space saver is the way to go I think. At least a little more piece of mind...and you still save a ton of space.
Cheers
Tush
glemon
There are lots of space savers with the correct bolt pattern, you also have to take into account the offset. Mine, from a Honda as well, I think Saab from the 90s will fit too, would not clear the front discs, except I already have a small spacer on for clearance with my wider wheels.
Gliderman8
I think you are correct... my space saver fits fine on the rear but needs a spacer up front. If I happen to get a flat in the front I will move one from the rear to the front then mount the space saver on the rear to get me home.
SkinnedKnuckles
I keep some fix-a-flat and an small air pump in the trunk (boot). Used it once in 20 years to make it home from a nail bite. Wire wheels here, so maintaining a reliable spare in the trunk can easily be forgotten for years and not good when needed.
Sarastro
You're tempting the Law of Innate Perversity of Everyday Life. It holds, in part, that if you have a spare, you'll never need it and it will seem like a waste. But the one day you leave home without it, you'll tear up a tire by running over a dead porcupine. You should realize that the spare is the thing that has prevented you from getting flats these last many years.
Gliderman8
What does a full size spare weigh approximately? 50#?
I’m guessing that’s a pretty good approximate. Tire is about 20-23 lbs plus steel wheel should be close to 40- 50 lbs.
Madflyer
All good words from guys that have been around the block. A word I bought a snow shovel before winter a few years ago and have only used it maybe three time ( Nevada). As for the spare I have 16 inch wheels on my TR 6 and as not to damage a wheel I could not replace I have five and with non direction tread can go either side of the car. I rotate all five ounce a year. And you right a lot of money just to go flat and or rot un used. any call is right. Madflyer
Gliderman8
I was wondering too, so I got out the scale. Full size TR6 steel spare (w/old Michelin Redline) is 40lbs, and the '97 Honda Accord space saver spare is 20. Bada boom.
So, did you decided to put the space saver tire in your TR6?
M
Martin Secrest
I did. The Honda tire fits well on the rear, but rubs on the front, so if I get a front flat, I'll have to swap two tires. But I'll be OK, lol. And there's a lot more room in the boot now, that's for sure.
Gliderman8
Yes, you are correct about the tire rubbing in the front. You can buy a wheel spacer for the front if you want. Like you, I will just swap two tires if I get a flat in the front. The additional room in the boot is an added plus.
glemon
I just removed the spacers that hold the spare cover up higher on my 250 since I have the space saver. Just drilled out the rivets. I then put some felt on the bottom of the cover so it won't scratch the paint. Had something I wanted to fit in the trunk and it didn't fit. Now it does, I can put the risers back on for originality if needed.
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
AngliaGT They Just Keep on showing Up Spotted 0
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT '78 Bonneville - Sell of Keep? British Motorbikes 3
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
Steve If you need a smaller SUV that will keep you alive... Rover / Land Rover 2
Lukens TR2/3/3A The hits just keep coming Triumph 2
T TR2/3/3A How can I bend TR4 air filters to keep them from hitting fender on TR3A? Triumph 1
R GT6 Fuel issues - hard to keep running Triumph 26
C BJ8 door strikers keep slippng Austin Healey 7
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
DanLewis Bugeye Door Latch - How to keep it from flopping around? Spridgets 20
beachbumbarry T-Series How do you keep girls off the TD MG 2
G TR6 How dry does your TR6 Hard Top keep you? Triumph 2
F TR2/3/3A Would you keep both a TR3 and 3000? Is it crazy? Triumph 37
F Would you keep both a 3000 and TR3? Is it crazy? Austin Healey 37
SkinnedKnuckles Of all things to keep me off the Road... Triumph 5
Stewart keep it or sell it MG 1
PatGalvin TR2/3/3A TR3 Intake Manifold - how to keep it looking good? Triumph 5
B Just keep on cranking out the oldies ! Restoration & Tools 3
T WHY do my battery connections keep corroding? Austin Healey 8
JPSmit Honest, It followed me home can I keep it? Spridgets 23
equiprx I keep gettting a wet dizzy. Jaguar 1
T Bonnet Latch Adjustment [how to adjust bonnet latch [BJ7] to keep it closed] Austin Healey 14
vping Another one followed me home. Can I keep it...too! MG 10
B Another one followed me home.Can i keep it..... MG 22
vping Engine Rebuild -What to keep and what not to keep? MG 22
regularman A plan to keep my sanity Spridgets 6
JPSmit the questions keep on coming Spridgets 6
Jim_Gruber Decisions Drive It or Keep Doing Body Work Spridgets 11
D Lowering a RB: Keep or discard rear sway bar? MG 7
mylillooker Battery keep going down... Spridgets 12
W Which carbs to keep? Spridgets 10
T keep it original v. improve it Austin Healey 44
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
RickB Talk her into keep it &join here! -was:64 Sprite.. Spridgets 4
Bruce_B New Wire Harness or keep the old one? Spridgets 4
BIBBER and the BERKLEY's just keep on coming... Other British Cars 13
J why do I keep doing this to myself? Triumph 2
Monark192 MGB 1974.5 MGB vs. 1975 model. Which to keep? MG 19
S KEEP ALL STOCK PARTS??? Spridgets 11
G Lets Keep Fall Fever Festive this Season! Triumph 0
jlaird This will keep you busy at work Spridgets 7
hondo402000 Keep Chrome wire wheels clean Triumph 3
Gerdo How to keep your plastic windows clear? Restoration & Tools 32
jlaird I keep finding bits of stuff Spridgets 0
1 Best ways to keep a 'B' Cold MG 6
Steve P. It pays to keep in touch with friends... MG 4
6 How do you keep after market rubber trim in place? Austin Healey 10
