Results 1 to 3 of 3
Thread: Zenith auto choke coming loose
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Jedi Knight sparkydave's Avatar
    Join Date
    Feb 2005
    Location
    Akron, OH
    Posts
    1,067
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    A couple times now, the screws on the auto choke assembly have managed to rattle loose, which usually leads to hard starting and leaking some gas. Thinking about putting a dab of blue Loctite on the threads, should that do the trick? I don't want it to be too permanent if I have to do a rebuild.
    1977 Midget 1500
  2. #2
    Yoda Jim_Gruber's Avatar
    Join Date
    Dec 2006
    Location
    Apollo Beach, FL
    Posts
    5,527
    Blog Entries
    2
    Thanks Thanks Given
    7
    Thanked in
    Re: Zenith auto choke coming loose
    Clean threads first, a degreaser, and then a little dab of Blue Locktite. Worked for me on my 210 Gear Shift Bolts. Tighten as tight as I could and they would come loose in 4-5 miles of driving. Blue Locktite did the trick. Issue fixed.
    Jim Gruber - Apollo Beach, FL
    Bugsy I - '68 Sprite w BE Bonnet - Gone but not forgotten
    Bugsy IV - '60 Bugeye - 1,275+.040 and a 5-Speed - CA Car - 2nd Owner from new - 10/12 Painting done, reassembly, cutting, and buffing in progress.
  3. #3
    Join Date
    Feb 2005
    Location
    Akron, OH
    Posts
    1,067
    Thanks Thanks Given
    Thanked in
    Thanks! Seems to be holding now. I'll keep checking but the screws don't seem to be moving on their own now.
    1977 Midget 1500
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
