Carb Help - Car idle slows and dies after being run for a while
PeterB
My car starts fine with the choke on and idles well for a while with the choke off, well after the engine is up to temp. Then if I contiune to let it idle or drive it a little, the idle seems to slow and the car stalls. Then when I go to start it, it has a hard time to start. I recently had my HS6 Carbs rebushed and then I rebuilt them in my BJ7. I checked the timing with an advance light and I am running 15 degrees as in the book. Distributer seems to be fine. I initially tunes the carbs after the car was warmed up so I am not sure what I am missing. Could it be vapor lock? Any thoughts.
Thanks as always for the help.
pkmh
One suggestion is to disconnect the fuel line to the carbs, but have line empty into a safe container and observe fuel flow while having the ignition in the on position, thereby activating fuel pump to ascertain if pump is working properly and or if fuel filters are clogged and or if fuel tank is clogged.
I had to totally redo my entire fuel line starting with the tank to rebuilding my carbs. All I can say is its a step by step process. Others here will be more specific as well.
Good luck.
Paul
steveg
When it stalls, can you undo the float chamber lids and see if the chambers are empty? That would confirm you've got a fuel starvation problem.
If you drive the car without idling, will it stall as it does at idle, or will it keep running indefinitely when you drive it? If the latter, no fuel starvation.
I rebushed my own HD8 carbs with new teflon bushings and the car would gradually die at idle, like yours. When I had Tom Bryant rebush with his solid Delrin bushings, the problem went away. He's a Volvo guy, so he's done that to hundreds of HSs.
When the car's idling, try squirting something around the throttle bushings. If your idle changes up or down, you've got an air leak at the bushing.
Edit:
According to this Joe Curto video there are 3 different float designs for the HS, with the possibility of the wrong float being used with a given cover - leading to a float that shuts off too low, causing fuel starvation.
See (starting around 10:00):
http://joecurto.com/su-float-bowl-covers
jimmyr
After many fuel related problems over the years, pumps, filters, clogs, etc, I have added a nice small fuel pressure gauge. Located it out of the way behind the hood brace, I cad quickly see if a fuel related problem has occurred. Thus localizing the problem to a fuel delivery or ignition etc.
P
PeterB
Thanks for the ideas, I will check them out this weekend. What leads me to the vapor lock it that the car runs fine at start up and for a while after that. It's only after 20 or 30 minutes of idling or stop and go does it start to act up.
pkmh
OK PeterB,
Possible about vapor lock. and aside from that, I heard something about gas caps having issues, too.
Question...When the vehicle stalls, it takes a little while before you can start her over and runs, yes? And then it stalls again after some point, yes?
If yes to both, then chances are it might be a clogged gas filter (in my opinion and was for me, anyway). There are filters, one right after the gas tank and one just before the carbs (if installed). Any others I missed?? Then your fuel pump might need looking into, as well. One step at a time.
Fuel filters are easiest to check, in my opinion (next to leaving the gas cap off?). Just my opinion.
again, good luck and keep us informed.
Thanks.
Paul
red57
Your first post is not clear whether it dies while driving or just when idling? If it is mostly at idle that you have a problem, I would consider it might be a little too rich and slowly loading up the plugs. I suggest let it idle until it dies and pull some plugs and see if they are sooty or wet or dry or whatever - that may tell you something about what is going on.
In my experience, most of the time vapor lock will happen when the car is fully warmed up after driving for a while and you shut it off to get gas or a short lunch break. Because there is no air movement the heat from the engine then soaks into the float bowls and heats the fuel. When you re-start it will pop & snort & spit and backfire for a while because it is trying to run on fuel vapor rather than liquid fuel. After a few minutes running, when it gets some cooler fuel from the tank and air movement cools the metal of the carbs a bit, it will settle down and be normal again. Lots of cars (like Datsun 240z) attempted to cure this by having a return line to the tank so there was always a source of cool fuel to the carbs.
This normally doesn't happen while continually driving because there is cool fuel and lots of air flow - but there can be exceptions and other explanations.
Dave
P
PeterB
Dave, I would say mostly at idling. I was trying to adjust my brakes after new shoes so I warmed up the car and was running it back and forth down a 400' driveway after my adjustments but there was a lot of idling involved. I will try again and pull the plugs as suggested.
P
PeterB
I think I found my problem. Running way too rich. Pulled the plugs today and they were black and just about dripping. I ordered a colortune to help me lean it out. I’ll let you know who I make out when it comes in.
thanks
steveg
John Turney
thanks
When you turn the key on, does the fuel pump stop clicking before starting? If the pump keeps running, the carb float needles may have some crud in them and leak.
bob hughes
Over-fuelling could well be the problem, I have experienced that - had to change the needles in the end. Also check the integrity of the low tension wire from the coil to the dizzy, I experienced a problem with that, the car would run for a while then stop, let it cool and it started up again, traced it to that wire - barely hanging on by the insulation let alone the wire inside.
:cheers:
kozelding
I agree, running super-rich can definitely foul things at idle.
Also, to veer back to the other side of the engine, I've seen a lazy centrifugal advance do something similar: after idling a few minutes, the weights in the distributor unstick and retard the timing beyond where you thought you set it.
steveg
Interesting about the sticky distributor weights.
Shouldn't checking the maximum advance to be 35 degrees at 3000 rpm validate that if it's the case?
coldplugs T-Series Help! Carb, intake, etc.. Car wont start MG 6
RGK TR5/TR250 SU carb ID help Triumph 6
jlaird MGB V6 carb help MG 14
D Rough running BT7 3 carb HELP Austin Healey 13
I Spitfire 78 spitfire carb connection help Triumph 8
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
K SU carb Help Spridgets 10
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
E Need SU Carb help Austin Healey 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
R Carb help, where to find it? Spridgets 4
Spriteman65 Carb help Spridgets 11
7 Carb help needed Triumph 6
I TR6 Carb help please for 69 TR6 Triumph 14
I Help with carb hook up for 948 Bugeye Spridgets 8
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
tweety Help me verify what to check with the carb.... Spridgets 0
Morris Help identifying carb set... Spridgets 18
J Seeking tri carb help Austin Healey 16
I TR6 69TR6 carb adjustment help Triumph 5
vping I need some carb help. MG 8
mountainman TR2/3/3A TR3 Carb Rebuild Help Triumph 1
newmexTR3 TR2/3/3A TR3 Carb help - crazy idle Triumph 12
I TR6 69 TR6 carb tuning help Triumph 8
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
LastDeadLast Help! In need of HS carb parts Jaguar 9
LastDeadLast Help!! HS Carb Part needed Triumph 20
YankeeTR Carb ID help.. Triumph 4
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
L Spitfire Help me make a carb choice [Spit 1500] Triumph 18
TR_JOE250 Spitfire Spitfire carb need help/opinions Triumph 6
I TR6 TR6 carb help Triumph 4
drooartz Carb help--idles too high Spridgets 7
R Carb leak help please Triumph 5
PAUL161 SU carb. problem. Help,Help,Help! MG 12
R6MGS Weber Carb Parts...HELP! MG 4
JPSmit Carb removal help Spridgets 5
George Zeck SU Carb Help !! ?? !! Spridgets 3
George Zeck SU Carb Help ...... Spridgets 6
J SU HS6 carb need help Triumph 10
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
