T-Series Dash for Sports/Racer
TRMark
Bronze
Thought I would post up a picture of the new dash for my Cooper based sports/racer. You guys have been very helpful in answering my questions and identifying parts as some are shared with a TD. When I redid the dash I decided to incorporate more TD parts to be more period correct. Besides, what has more quirk than a TD and that is what I was going for. There were several Cooper/MG specials built in the early 50's. The most famous is JOY 500, kind of inspired me. My friends kinda shake their heads when I explain how the directional signals work.
JPSmit
that looks amazing! (have we seen pictures of the actual car?)
TRMark
TRMark
Bronze
It is coming out pretty well. There are more pictures of the car at my profile page. To understand the car, one needs to understand the Cooper cars built by John Cooper in the late 40's and early 50's. It is a wonderfully weird little car, especially this one with the sports/racer body and an Alfa engine.
JPSmit
Ooo pretty. (nice TR too) and clean garage!
Do you know the story?
TRMark
TRMark
Bronze
Not the early history although there is a bit of history on the car itself, bottom hinged doors since welded up prior to my ownership and ground down welds on the frame tubes indicating previous engine. I bought the car in very rough condition in 1969 powered by a very worn out 750 series Alfa 1300, block number dated the engine from a 1956 Alfa. The car is titled a Gemini, although it shows no relationship to either a Gemini or the earlier Moreland. The suspension is purely Cooper with propitiatory castings and other parts. Diff in an ENV placed in a fabricated housing for IRS, typical of Cooper front engine cars. I replaced the engine with an Alfa 1600 in the early 70's because one became available. In the later 70's I started auto crossing and hill climbing the car. I switched to Formula Vee tires. The car was quick through the gears, even posted TTD at a statewide autocross meet in about 1985. With the modern sticky tires, larger engine I managed to break stub axles, the increase grip twisted the weak chassis and caused cracks in the aluminum body. I pretty much ruined the little thing. The engine started to give problem so I put the car away for a couple of decades. I thought I might like to go vintage racing so I put a roll structure in it in about 2007, lost interest and put it back in storage. I built a decent shop, and learned some metal and painting skills; acquired some fabrication equipment. I restored my grandfathers 42 John Deere B and then the TR4. About a year or so ago I decided to restore the sports/racer. I intend to license the car again and very carefully drive it occasionally. Probably more than you wanted to know.
JPSmit
Not even close to all I want to know - just such a fascinating car! thanks for sharing
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
C How to remove entire dash panel on BN6? Austin Healey 4
6 Dash refinishing help Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
D Stromberg Dash Pot Screws Jaguar 3
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
