Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Rear Oil Galley Plug Sealing
  1. #1
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanks Thanks Received
    Thanked in
    So, I've been fighting a leak for a while. I removed the transmission with engine in car using a tranny jack which is actually easy than pulling the whole engine IMHO. I bought some new aluminum plugs from TRF, some thread sealant and put the new plug in. I let it sit for a day, threw everything back together today, started the car and it still leaks. My concern is, the plug that was in before was easy to remove because it wasn't screwed all the way so extracting it with a bolt remover was easy. The new one I put in I cranked down with the pliers and added the high temp thread sealant. So I KNOW it's going to be much tougher to remove. I'm annoyed to say the least but does anyone have any recs for sealant? How about using good ol red gasket sealant (RTV) on the threads? Seems to work everywhere else on the car! I've seen on the other forums that people used SAS Brake & Air sealant (not readily available here) and Wellseal and that's it. If I'm going to tear this thing apart again I want to make sure I seal it. Maybe I should just JB Weld it. Kidding! But it has crossed my mind. Thoughts? Next is still figuring out my blinker problem I posted about back in...2018?
    Gary
    1962 (Nov Build) Triumph TR4 CT/16836L Restoration in process
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,612
    Thanks Thanks Given
    6
    47
    Thanked in
    Re: Rear Oil Galley Plug Sealing
    Did you run a tap through the threads and clean completely dry with brake or carb cleaner? One issue with those plugs is they are straight thread, not tapered like a pipe thread. For that reason you have to clean the threads completely and use a gap filling type sealant. I would have thought your thread sealant would work, so long as the threads were clean. red RTV is not the best for oil applications. The black RTV would be better. Also pipe sealant, gasket maker, and the like. JB weld should also work.
    John
    1955 TR2
  3. #3
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    Quote Originally Posted by CJD View Post
    I did clean them thoroughly with a brush, then used a toothbrush with brake cleaner. Made sure they were squeaky clean! I lubed up the threads GOOD too. Made sure not to get too much on the internal side, but enough to hopefully seal on the sealing edge. So red gasket sealant isn't good for oil? I've been using it on my oil pan and it's worked great. And quite a few people here recommended it. Thought it was the same as black, but more high temp. My dad mentioned running the plugs thru a pipe thread tap to taper the plug but as anyone been able to find a plug at a local plumbing store anywhere that has fully tapered threads? I'm sure it's some odd size.
    Gary
  4. #4
    Join Date
    May 2012
    Location
    Robbinsville, NC; Everglades City, Fl
    Posts
    663
    Thanks Thanks Given
    11
    Thanked in
    Don't try to change the threads. Is there a copper washer under the head of the plug?
  5. #5
    Obi Wan LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    2,079
    Thanks Thanks Given
    26
    Thanked in
    I use hard permatex on anything that can leak, and all else fails. Figure I am not taking it apart again seal it permanent. Might be hard to get back out down the road, but you bet it's sealed. Also figure if I still have the car, I know what I did.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual (parts car),
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  6. #6
    Join Date
    May 2012
    Location
    Posts
    663
    Thanks Thanks Given
    11
    Thanked in
    I had the impression from your earlier post that you were troubled by the plug in the gallery leading to the filter, which appeared in the Moss catalogue to have a head. I see from your photos that this is not the problem and no washer would be involved. Still, don't change the threads.
  7. #7
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    Quote Originally Posted by bobhustead View Post
    Correct. I wouldnt be changing the threads on the block, but trying to find a plug with full tapered threads so it fills in more of the void between the threads.
  8. #8
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,612
    Thanks Thanks Given
    6
    47
    Thanked in
    Then thicker sealer is in order.
    And yes, red RTV is not recommended for oil applications. The lighter the oil, the quicker it breaks down. As with many applications...it will work with oil...just there are better, recommended choices. The black RTV is made for oil pans and diff covers.
    The problem with opening up the threads to taper pipe threads is finding a plug that clears the flywheel. As long as you can it will work...but there is no reason you cannot get the OEM style plug to work with the right sealant.
    John
    1955 TR2
  9. #9
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    Well...guess we shall see if my oil pan leaks with red gasket maker. If it does at least that is much easier to fix. I ordered some Hondabond on Amazon as that seems to be what a lot of people rave about if you want a good seal. Ill be waiting a couple weeks to retackle this. May as well take out the gauges and have them shipped off for refurb. Same with the brake and clutch slave cylinders as they are oozing a bit. Get some brass sleeves put in. What else can I tackle? Hmmmm...altenator/generator? Haha
    Gary
  10. #10
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,612
    Thanks Thanks Given
    6
    47
    Thanked in
    If you have already used the red, then don't worry about it. As long as you don't have globs hanging inside the pan it will work fine. Sounds like you'll have a mechanically new car when you're done!
    John
    1955 TR2
  11. #11
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    Well...the rest of the car is practically new! HAHA The 4 gauges work, the tach works, but the speedometer is sticky. I've also been stuck out after dark a couple of times and can barely read the gauges so some LED's might be in order. First I have to get the darn blinkers to work. I've done some troubleshooting and I think it's a crap flasher (second one) and maybe voltage stabilizer. All my wiring is right with no shorts, switch is good and it's a new harness.
    But...first...need to get this plug fixed. So, as I expected the new plug wouldn't come out as I had it TIGHT. I tried drilling it out carefully. Well...didn't go as planned. So what are options? Enlarge the hole and tap new threads and get a tapered plug with a hex socket in it? Use a tapered aluminum plug and hammer it in?
    The other issue will be cleaning all the old aluminum and metal filings out of the track. I will have to change the oil, I know that. Thing that stinks is I JUST changed the oil with Brad Penn 10W-40 as this is it's FIRST oil change after the break in oil. Think I can recycle/reuse the oil and filter it somehow? I reallllly don't want BRAND NEW oil going to waste. Zero miles on it. Going to have to figure out how to flush out the big stuff. Thinking a metal rod like a gun cleaner with some cloth and get a hollow rod and put that in it, then once inserted push the cloth end out and pull so it's only catching on the pulling out movement.
    Sorry...a lot in this post.
    Gary
  12. #12
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,612
    Thanks Thanks Given
    6
    47
    Thanked in
    Bummer.
    I know you’re wanting the “it’ll be fine” answer. Unfortunately, it probably won’t. That gallery supplies the crankshaft and rocker shaft. The drilling’s are not going into the pan...rather, they are going right to the crank journals. To be honest, if it were just aluminum, I might be tempted to run it, as aluminum is soft and steel usually beats aluminum. If you got ANY cast iron in the gallery, though, just think for a bit about sharp, curly bits of cast iron being held against your fresh crank journal with 70psi pressure.
    There is only one right answer, and that is that the engine has to come back apart to clear the galleries.
    There is a “might work” answer...assuming you were very careful to minimize the swarf. You could remove the last Gallery plug on the left side of the block and blow air through there. Alternate between carb cleaner and air until you are absolutely certain you have every tiny bit of swarf. If any swarf made it forward of the last plug, then this will blow the swarf deeper into the gallery and also trash the middle crank bearing.
    Even if it’s a low chance of iron in the gallery...the ramifications if there is any are quite severe. They include: Loss of crank, loss of bearings, scored sleeves, loss of rockers and shaft, loss of cam and lifters. I feel for you as it is a tough decision. If you go the right way, all you are out is a gasket set and your time.
    John
    1955 TR2
  13. #13
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    Bummer.
    Nope definitely wasn't expecting the "it'll be fine" answer. I knew it was going to be work. Irritates me that the plug didn't hold the first time. I'm just going to throw the FW/Clutch/PP back in, bolt up the tranny so the engine has rear support, drain all fluids and deal with it this winter. I'm in an apartment and my garage is quite big, but lighting isn't the best and just don't want to do it here. I'll wait till I buy my house and do it then. Not like it was getting registered this year with the whole COVID thing anyway since all the county offices shut down. It is a bummer to be taking apart a 500mi driven engine but I'll take it to an engine shop once it's all torn down and have them weld that thing shut so I KNOW it doesn't leak. But then I'll probably get a head gasket leak or somewhere else since it's all good and sealed now.
    Good thing is, like you said, it's mostly just a gasket set. Should be able to reuse my ARP head bolts as long as they aren't too stretched but all my bearings will still be good! And time...something I don't have right now or care to spend working on this car. Guess I'll get the frame looked at too and have all the other minor things addressed when the engine is out. Constant project/money pit! HAHA Thanks for all your help! Ohhh...maybe a V8?
    Gary
  14. #14
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,612
    Thanks Thanks Given
    6
    47
    Thanked in
    All your studs will be fine. The ARP for at least the next 3 dozen rebuilds! Sorry about the trouble, but I think you're making the right decision. One thing, I'd advise against welding the plug in. Over time the stress from the weld will likely cause a crack. If you really don't want to mess with the aluminum plugs any more, then go the pipe plug route. Just use a plug that you are sure will not block the rocker shaft oil hole, or foul the flywheel on the back side.
    When you get around to cleaning the gallery...best to use different size rifle cleaning brushes. At least remove the crank, side gallery plugs, front plug (which means the front engine plate), and rocker shaft. Everything else can stay assembled. All cleaning should be done from front to rear, and from bearing journals to gallery. The rocker shaft feed need only be blown downward with solvent and air.
    John
    1955 TR2
  15. #15
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    It is what it is. Not everything can be perfect and no point in getting upset. Old me would have. New me...what good does it serve? To me it's just another project and that's fine. I understand the welding issue and I was probably just going to have them re-tap the hole so I can use a plug with a hex socket so if it does leak again it's easier to take out and reseal. Be nice to use a bolt with washer but not enough clearance.Of course now I bet my rear main seal will leak even tho it's nice and dry now. Luckily I have the upgraded one so should be easier to reseal. But it'll be fun to tear apart and put back together. Biggest thing is I want to try and leave untouched is the 89mm sleeves and figure 8 gaskets so I don't have to try and gap them again. That was a PITA. No reason those should come out, right?
    Gary
  16. #16
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,612
    Thanks Thanks Given
    6
    47
    Thanked in
    The sleeves can definitely stay in place. And, actually, if you are careful in taping the rod journals on the crank, you can likely just push the pistons up and leave the head and pistons in place...although I have not tried that myself. In theory it can be done.
    John
    1955 TR2
  17. #17
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    3,219
    Thanks Thanks Given
    15
    68
    Thanked in
    Could you use a magnet on a rod in the oil gallery to collect any cast iron filings if any?
    If you retap to a tapered pipe thread there are brass plugs with an internal hex you could use to seal it up.
    Understand the situation I had a leak from my front plug. That one came out easily with an extractor. Probable why it was leaking in the first place.
    David
    TR3A TS75524L
  18. #18
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    Quote Originally Posted by DavidApp View Post
    David
    I thought about that. Problem is, the plug was aluminum and there are lots little bits of that as well. Why risk it? If I try and flush it may push it in to the other little crevices and come out later on. There is no rush on this. Have had the car since 2002. Finished it in 2018. Didn't drive it in 2019 since I was traveling and 2020 I can't register it. So I'll just take another year to get it really dialed in and hopefully 2021 I can fully enjoy it. But yes, re tapping and having a brass or some sort of plug is what my goal is. Tearing it down will be easy. Just got to make sure I mark the bearings, chains, sprockets and all that before taking apart since I know it's all in time right now and that it all goes back together the same way it came apart.
    Gary
  19. #19
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    3,219
    Thanks Thanks Given
    15
    68
    Thanked in
    While it is apart you may want to look at the timing chain cover. This is what I found when I had my one back apart early this year. Do not know if I missed it when I did the rebuild or it was the result of a new tension spring.
    David
    TR3A TS75524L
  20. #20
    Join Date
    Mar 2015
    Location
    Denver, CO
    Posts
    285
    Thanks Thanks Given
    1
    Thanked in
    David
    Yeah, everything will be looked at. Engine was completely rebuilt 500mi ago with new pretty much everything, cleaned, lightened and balanced some stuff because why not. Good thing is when I I first started it I think it ran WAY too hot so may have cooked it a little so the nice thing is itll give me a chance to clean it out again as Ive noticed some brown film in places from it being overheated. I have it dialed in now so taking it apart and putting it back together should be easy...as long as I can get it sealed again. But I probably just jinxed it by saying it would be easy. Haha. Till then...maybe Ill start a new thread when I start the tear down. Get some input!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
