Opinion on spark plug color
G0bigred
1960 Austin Healey 3000 BN7 just recently replaced my ignition coil and am syncing the carbs up myself. Here are what my spark plugs look like. I think they are pretty dang close. What adjustments do you think I should make (if any)?
mgtf328
I looked it up in my SU Dictionary of Terms. A 'little' is quarter turn of the adjusting screw, a 'bit' is eighth of a turn and 'do nothing' is don't meddle.
For what it's worth, I'd adjust the rear carb a 'bit' and the front 'do nothing' and try it for a few miles to see how it balances out. Bill Rawles told me they like to run rich and it's seems to work for me.
AJ
G
G0bigred
Ha thanks! Great definitions. Just adjusted the rear carb an eighth and the front a 16th. I’ll take it on a run and see how it looks.
Deleted member 21878
not to insult in any way... but not knowing how you check your plugs, i would offer this.
i was always told this:
first, make sure your timing and valves are adjusted correctly.
Then take the car on a twenty mile run to make sure it is good and warmed up. the last ten miles don't let the car go under 2500 RPM's. if you have to slow down, shift down but keep the rpm's up. No idling. when you get to a place at the end of those ten miles you can pull off, shut off the engine and drift to a stop. lift the hood and check the plugs.
This gives your car time to clean up the plugs and a more accurate check of what the car is doing at speed. better for the car to run a little rich around town than to run lean at speed.
i have a place 10 miles from home i drive to and then turn around. on the way home i keep the RPM's over 2500. when i get back to my drive, i shut off the engine and drift to the shop. let the car cool a little and then pull the plugs. i know other guys who have taken their plug wrench with them because the have to stop going home.
Michael Oritt
DD--
You said: "Then take the car on a twenty mile run to make sure it is good and warmed up. the last ten miles don't let the car go under 2500 RPM's. if you have to slow down, shift down but keep the rpm's up. No idling. when you get to a place at the end of those ten miles you can pull off, shut off the engine and drift to a stop. lift the hood and check the plugs."
It's always nice to take a 20 mile ride but it's not necessary to find a highway on which to do a spark plug check. After the engine is at running temperature you can simply get up to around 3000-3500 rpm's and hold there for 10-15 seconds, then while holding there switch off the key and come to a rest.
Roger
Bronze
The Lodge plug is from my Austin Seven. Lodge Sintox plugs were popular at one time back in U.K., especially for racing.
They are still available, though they haven't been made for 50 years or so.
The plug shown can be disassembled, and the electrode removed for cleaning, which was a very useful feature in cars with plug-oiling tendencies.
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
F TR2/3/3A Inner sill opinion Triumph 38
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
J TR2/3/3A Need opinion on gear reduction starter for TR3A Triumph 23
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
M Looking for opinion on keeping original parts for my modified Healey Austin Healey 8
R General Tech Kirk Racing headers opinion Triumph 3
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
R My first LBCS ... Caution unbiased opinion Spridgets 20
glemon Opinion/Experence Rocker Shaft Wear Triumph 6
B Gas tank sealer...whats your opinion? Triumph 29
Got_All_4 Wedge Need opinion on TR7 value Triumph 3
L Opinion as to value, BJ8 barnfind. Austin Healey 45
T Wire wheel repair / rebuild opinion in SoCal Triumph 3
drooartz Pulled carbs and intake, need opinion. Spridgets 7
scoutll This guy has a high opinion of his car Spridgets 8
Stinger TR4/4A TR4A Bullet Racing Style Mirrows Opinion Triumph 9
D Opinion of the Worst Cars Triumph 40
1 opinion on top for sale. Austin Healey 28
R Need a Second Opinion Spridgets 17
Jim_Gruber Need an opinion - Leave alone or straighten fender Spridgets 29
chrpark Your opinion on undercarriage treatments Spridgets 16
chrpark Your opinion- engine and trans removal as a unit? Spridgets 8
Baz What's the opinion on Porsche 914's? Other Cars 19
germanmichel Please give me your opinion. pacific or brg ? Austin Healey 21
Trevor Jessie Electric Fan Opinion Spridgets 16
2wrench Opinion on intake and exhaust manifold studs Triumph 5
BOBBYR Whats your opinion? Austin Healey 29
T Opinion on Rockers? Triumph 11
H Riley Opinion Other British Cars 6
69MGC Opinion on worth Triumph 8
M Can I get an opinion on another car? Spridgets 31
Z Engine opinion Spridgets 10
G Opinion on tranny oil leak Triumph 9
hondo402000 state your opinion on posts Triumph 0
M 'New Product'OPINION's DUPLICOLOR's 'SHIELD' Triumph 0
N Ignition Opinion Question MG 21
T Opinion needed - replace or relocate? Spridgets 6
T I need an honest opinion Triumph 9
69MGC Painting Opinion MG 12
bfitz TR2/3/3A TR3 opinion wanted Triumph 14
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
