TR2/3/3A Door fitting- graduate level
Jim_Stevens
Great, another door fitting question you say?
Ok, the doors fit fine pre-painting, all hinged up:
They also fit fine now after painting, just like shown above, BUT only when held in place, door latched, with the hinges laying flat and NOT screwed into the A-post.
When the hinges ARE screwed in, the aft edge of the outer wing interferes with the door such that it can’t be closed and paint touches paint at the front door upper edge. The outer wing is firmly bolted into the A-post with a no-gap fit.
I don’t see how shimming the body would help, since I have nice even gaps all around the door. Might this be a time to shim the hinges? I did just check- the repro hinges are the same thickness as the originals. The body was removed from the chassis for painting, and one could reasonably assume the same shims were used post-painting, but the body shop did that and they are out on CV19 lockdown.
What say ye? Shim the hinges? Jim
TS44744L”O”
Graham H
I made all those adjustments before painting mainly by bending the hinge mountings in the doors by dollying them forward trial fit umpteen times until happy with end result, but after painting you could look at shims.
Graham
CJD
A pic of the bolted door would help. I think you are saying that the when you tighten the hinge the door moves forward? Or, are you saying it moves forward as the door pivots open?
charleyf
Jim,
One other option is to try readjusting the front fender. You only need a very small movement of the fender to allow the door to clear. The movement would likely be to try to pull the fender out.
Jim_Stevens
Jim_Stevens
I’ll try pull the fender out...
what is happening is that you need to have the door open to screw in the hinges, right? And when I do, the top part of the door sits in too far to clear the valence without making contact. I’ll take a picture on my next try! As always, thanks!
DavidApp
I did have to adjust the number of shims between pre painting and post painting.
It seems that every time you remove and reinstall the doors things are slightly different.
David
charleyf
I agree with David. I am still in the pre-paint stage and have put on and taken off the doors well over a dozen times. One thing that I have noticed is that there is a very small bit of variance in what we think of as the fixed position of the hinges to the doors. In this I mean that when you go to tighten down the hinge screws you can often times move the door a very little bit prior to the final tightening of the screws. I have noted that this small movement is enough to make things fit or not fit. Logic says that there should not be a variance in the final position with the screws tightened down. But there is. When you think about the ability to move the door in or out and up or down it might be just enough to get you to the sweet spot. From there you can look at shims to move the door back or change the angle of the door.
DavidApp
Also the build up of paint on the hinges, "A" post and door will make some difference. I think I remember grinding the paint off the hinge faces to get a good fit. It was a trying time as I was worried I would damage the paint each time the door came off or was reinstalled.
David
sp53
A couple of things come to mind. Sounds like you could get some thin stainless steel washers put them between the post and the hinge on the back. Maybe fender size washers or smaller depending on where you put them on the post and hinge and I suggest 5/16, so they can move some. If the tub was off the body, then the gap could be a shim on the inner area problem. Are the A and B post parallel?
steve
Jim_Stevens
Jim_Stevens
Update: Holding the door in place, I can see quite a gap between the hinge and the A post. I have some 2” flat bar stock that may be the right thickness that I can drill out to make a shim... I can do that during a coffee break while I’m here stuck at home working.
10-hours per door indeed! Jim
Graham H
Jim, your photo shows the door not yet final painted so you could try to bend the frame hinge mounts to take up the gap.You may find the area where the hinges mounted to the door is bent in so if you use a suitable drift inside the door and give it a wack both top and bottom and refit it won't take much , if you go too far just tap it back a bit and try again
Graham
CJD
Like Graham says, the hinges can be spread at your stage in the build. The brass hinges are a bit easier than the steel, but both are bendable.
Jim_Stevens
Jim_Stevens
John, in the another forum, you said that adding packing to the outrigger wouldn’t affect the top door gap.
I added 1/16” shims to the top and bottom hinges to move the door aft. Better, but still can’t get the door to close due to the top door edge striking the fender.
Seems to me “in theory” that adding more packing especially on the front outrigger will cause the body to hog (as a wooden ship) thereby fixing the issue. There’s no packing in there now.
Thoughts? Jim
CJD
By the way, the car is completely painted.
Important safety tip!
I remember having the same issue on my driver's door. I had done welding to the edge of the scuttle and front fender, and it turned out my edges were thicker than normal. I had to thin the thickness of the fender and scuttle weld beads. This gave room for the door edge to pivot behind the forward and top edges. I also rounded the edges of the gap there...again to provide room for the door to open. Could this be your issue? If you take some of the thickness from the back of the edges you could then use touch up paint on a brush to re-cover them...they do not show from any normal view of the car.
The other option is to adjust the door panel a slight bit inward. Again, the goal is to give your door edge room to rotate behind the scuttle edge as it opens.
As I sit here, I think I might have even had to open up my forward gap slightly to allow the door to open properly. Of course this is not an option on a painted door. It seems like I remember a single point on the upper edge of th door that becomes the "critical" point in forcing the amount of clearance for the gap. In your case moving the door back and downward as far as practical would help.
sp53
2 things I would look at are; is the fender all the way forward on the A post at the top? Can you put a feeler gauge in that spot? If so, then the fender can go forward. Another option would be to bend the actual hinge outer flap out and down so the door moves how you want it. You might have to bend both. Some people pound in the door at the hinge, but I like bending the hinges. I learned it from an old cabinet maker. I do not understand when you say there is no packing. You mean there are no shims on the outriggers? If that is the case you need 4 on each outrigger.
steve
Jim_Stevens
Jim_Stevens
Success!
I put another shim 1/8” this time on the hinge on the door side and that did the trick.
So, that was two 1/16” shims on the A-post side and this 1/8” on the door side top hinge. Now, onto the passenger door forearmed with this experience and y’all’s expertise! Once we shim that one, doors off and I’ll take all the shims to be powder coated body color.
I think I can still reach my goal of Father's Day on the road, although the show at which I had wanted to show it has probably been scrubbed.
Thanks all again— Jim
TS44743L “O”
tallguylittlecar
Just an observation, I was just out working on color sanding and buffing the shell, which is why I noticed this--it looks like you are missings the holes on your quarter panels for the tonneau studs. Someone correct me if I am wrong, could just be the picture and the white color is hiding it. Doors look great.
charleyf
Jim,
if you powder coat the whole shim, you will be adding two layers of paint thickness to the shim. You really only want the edges painted of those slims.
That tonneau stud that appears missing I believe is a bolt with nut. So needs to go in before the interior panel.
M TR4/4A Sequence for fitting door glass? Triumph 7
TR4A_IRS TR4/4A TR4/6 Door Fitting Triumph 3
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
CraigLandrum TR2/3/3A TR3 door fitting tips? Triumph 16
Jim_Gruber Door Fitting - A-Pillar Skin - Success Spridgets 5
jjbunn New Door Lock Fitting Triumph 3
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 0
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
