Results 1 to 16 of 16
Thread: Oil leaks
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Question Oil leaks
    I can't believe that I've not posted for almost 2 years. I finished the car (almost) in the summer of 2018. It runs and drives pretty much flawlessly. Now with some extended time at home, I've decided to address some minor issues. The main thing is excessive oil leaks. It absolutely leaves a few black spots every time I park it. I know the rear main seal leaks (like all 948's) but it is also leaking around the valve cover and and engine side covers.
    IMG_0473.jpg IMG_0435.jpg IMG_0450.jpg IMG_0454.jpg IMG_0457.jpg IMG_0458.jpg
    Any hints and tips for the best way to seal these? The valve cover has a cork gasket and was sealed with Hylomar blue. I'm surprised it leaked, and it only seems to be in one place. Hopefully cleaning and re-sealing will address that.
    The side covers leaked a lot. On these I used rubber gaskets with no sealant, clearly that didn't work. They also leaked around the bolt hole where there was no gasket, just a metal washer.
    Hopefully addressing both of those will help a lot. I'm then thinking about a catch-can of some sort for the oil that leaks from the rear main. Anyone have experience in making one of these? I remember seeing something a while ago, may it was posted here on BCF.
    David Doan - Frisco, TX
    david at doan.us
    http://doan.us/blog/bugeye/
    1959 Bugeye - AN5L-26655
  2. #2
    Yoda Boink's Avatar
    Join Date
    Oct 2011
    Location
    Portland, OR
    Posts
    5,640
    Thanks Thanks Given
    5
    16
    Thanked in
    Re: Oil leaks
    Can't resist... that's quite the panel of relays you have there. Can you shoot a photo of just that?
    - Mark
    Former 1956 Austin Healey 100-4 (BN2)
    Former 1962 Mk1 Austin Mini (850)
    Former 1973 Austin Mini (really a 1980s Cooperized Mini)
    Present 1959 Austin Healey "Bugeye" Sprite (with 1275, 5 speed, discs, etc)
  3. #3
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Re: Oil leaks
    Quote Originally Posted by Boink View Post
    Here you go: http://doan.us/blog/bugeye/index.php/2018/06/17/wiring/
    I made my own wiring harness, and I thought I had posted about it here. I will try to find the details if anyone is interested.
    david at doan.us
  4. #4
    Yoda Boink's Avatar
    Join Date
    Oct 2011
    Location
    Portland, OR
    Posts
    5,640
    Thanks Thanks Given
    5
    16
    Thanked in
    Re: Oil leaks
    Thanks David. THAT is quite the wiring job (dash, panel in the engine-bay, etc.)!
    - Mark
  5. #5
    Jedi Warrior Nelson's Avatar
    Join Date
    Apr 2005
    Location
    Medina, Ohio
    Posts
    533
    Thanks Thanks Given
    2
    Thanked in
    Re: Oil leaks
    I made an oil catch tray a while back. I used a bread pan and added a drain so I wouldn't have to take it off to dispose of the drippings. I tried to attach photos but don't see them in the preview. I'll try again if they didn't attach. I see they are too big. I will reduce them and try again.
    Nelson
    Original owner '62 Mk 2 Sprite aka Little Mo
  6. The Following User Says Thank You to Nelson For This Useful Post:
    David_Doan  (05-18-2020)
  7. #6
    Join Date
    Apr 2005
    Location
    Medina, Ohio
    Posts
    533
    Thanks Thanks Given
    2
    Thanked in
    Nelson
  8. The Following User Says Thank You to Nelson For This Useful Post:
  9. #7
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Re: Oil leaks
    Quote Originally Posted by Nelson View Post
    Thanks Nelson, but the attachments don't load
    david at doan.us
  10. #8
    Join Date
    Mar 2018
    Location
    NSW, Australia
    Posts
    9
    Thanks Thanks Given
    1
    1
    Thanked in
    1 Post
    Re: Oil leaks
    The tappet covers should have a cupped washer and a rubber seal for the bolt.
    For the rocker cover I use contact cement for the gasket to the cover, this keeps it in place and makes it re-usable. On the head side of the gasket I smear grease for the seal.
  11. The Following User Says Thank You to Mk3Sprite For This Useful Post:
    David_Doan  (05-19-2020)
  12. #9
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Re: Oil leaks
    Quote Originally Posted by Mk3Sprite View Post
    Thanks for the tips.
    david at doan.us
  13. #10
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,254
    Thanks Thanks Given
    52
    Thanked in
    Re: Oil leaks
    I have posted the following information before so I'll try and be succinct as possible.
    Assume the valve cover and tappet covers are somewhat warped. Look for the twists and warps and flatten them to the extent possible then proceed with the steps below.
    1. Remove the covers and scrape off the old gasket and sealant from the covers, the block, and the head.
    2. Clean those surfaces with a paper towel wet with brake cleaner or similar.
    3. Apply a thin film of grease to the flat surface of the openings to the block and the top of the cylinder head.
    4. Press the gasket firmly into the thin layer of grease so it is stuck to the machined surface.
    5. Now apply a thin bead of RTV to the cover in the gland where the gasket will sit.
    6. Fit the cover to the block or head making sure the gasket remains in contact with the machined surface.
    7. Fit the fasteners to the cover and tighten them finger tight (no wrenches).
    8. Leave the covers like that over night and in the morning tighten the fasteners to the specified torque.
    9. I forget the order of the fasteners and washers for the tappet covers but make sure those are installed in the right order and apply a bit of your Hylomar (or similar) to the side cover washers.
    If you take these steps the gasket will make intimate contact with the flat machined surfaces on the engine. The RTV both bonds the gasket to the cover and fills any gaps present due to the covers not being flat.
    Once you do this you will be able to remove and reinstall the covers a few times without introducing leaks or needing to replace the gasket.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  14. The Following User Says Thank You to dklawson For This Useful Post:
    Rut  (05-20-2020)
  15. #11
    Join Date
    Aug 2013
    Location
    Damascus, MD
    Posts
    2,058
    Thanks Thanks Given
    3
    12
    Thanked in
    Re: Oil leaks
    Aircraft Spruce sells a nice drip pan that you can use for leaks. If it can catch the oil from a radial engine, it sure can catch the oil from an A-Series motor. It's plastic, so if you accidentally run over it, it will snap back into shape unlike a metal pan.
  16. #12
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Re: Oil leaks
    Quote Originally Posted by dklawson View Post
    Two of you guys recommending grease on the engine side, I will give that a shot tomorrow. New gaskets came today
    david at doan.us
  17. #13
    Join Date
    Mar 2005
    Location
    Posts
    6,254
    Thanks Thanks Given
    52
    Thanked in
    Re: Oil leaks
    In the method I wrote about, the grease is used like a thin film glue and release agent. If I used some other assembly method I would not use the grease.
    Doug L.
    '67 Triumph GT6 Mk1
  18. #14
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Re: Oil leaks
    That's what I meant. I have found multiple recommendations to use sealant on the valve-cover and grease on the head with cork gaskets. The same for oil pans.
    david at doan.us
  19. #15
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Re: Oil leaks
    This seems to have worked, thank you.
    david at doan.us
  20. #16
    Join Date
    Mar 2005
    Location
    Posts
    6,254
    Thanks Thanks Given
    52
    Thanked in
    Re: Oil leaks
    I am glad it worked for you. Thanks for posting the update.
    Doug L.
    '67 Triumph GT6 Mk1
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
