TR4/4A Voltage Stabalizer and Fuel Gauge Readings
karls59tr
I installed a TR4A voltmeter in my TR3 when I converted to an alternator. I put a new voltage stabilizer in line in front of the fuel gauge to lower the voltage to 10 volts as required. The gauge works but the dial will only read a little before the half way mark when the tank is full? Is this an issue with the stabilizer or does the tank sending unit float arm need to be bent? The sending unit float is centralized and not hitting the sides.
Sarastro
Is it a modern replacement stabilizer or an original-type stabilizer? If it's a modern one, the problem is almost certainly in the fuel gauge. If it's the older type, it could be either.
The modern stabilizers give you a constant 10V. The original ones turned on and off periodically, with the expectation that the average output voltage would be more or less sorta like maybe approximately 10V, maybe. The gauges were so slow to respond that it didn't matter much. But if the stabilizer failed, pretty much anything could happen.
The most common failure mode for the modern ones is that the input fuses to the output, so you get whatever the system voltage is, 12-14V; occasionally, when totally zapped, the output is zero. So, you'll get either a high reading on the gauge or nothing.
dklawson
Karl, I have three background questions.
1) Why did you decide to install a new voltage stabilizer?
2) When did the fuel gauge last read correctly for you?
3) Assuming the temperature gauge is electric, how is it reading? Is it also reading low?
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
S TR2/3/3A grounding the voltage regulator Triumph 14
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
T TR4/4A Why is the new voltage stabilizer I got marked with 'top"? Triumph 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR4/4A voltage stabilizer Triumph 2
Jim_Gruber Voltage Regulator Question Spridgets 4
S TR4/4A Voltage stabilizer and cable routings? Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
NutmegCT Voltage gauge Restoration & Tools 1
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
S TR4/4A voltage regulator - digital Triumph 13
Mink TR4/4A Moss voltage stabilizer, part number 131-555 Triumph 15
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
steveg Heater Blower voltage drop Austin Healey 8
M TR2/3/3A Voltage regulators Triumph 5
cmacmillan TR6 Losing voltage at + side of coil Triumph 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
M TR4/4A Voltage Stabilizer question. Triumph 10
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
Zimmycobra TR4/4A Question on Voltage Stablizer Triumph 6
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
Darrell_Walker High battery resting voltage - sign of imminent demise? Triumph 15
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
M pre adjusted voltage regulator Spridgets 4
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
H Tr 3 Voltage regulator Triumph 6
M TR4/4A Voltage Stabilizer TR4A. Triumph 14
6 Voltage Output Question Spridgets 3
Superwrench Voltage Reg Austin Healey 1
J TR4/4A TR4A voltage regulator help Triumph 16
G low voltage to right side turn signal Austin Healey 3
Bob Claffie Voltage stabilizer Triumph 10
A Headlight Voltage Drop MG 5
N DC voltage output f Austin Healey 2
G Only voltage gauge works Triumph 10
Twosheds Voltage Regulator Lecture Triumph 11
M TR2/3/3A tr-3a Voltage Regulator Triumph 25
M voltage regulator adjustment hard Spridgets 18
