H6 Carb Mounting
Editor_Reid
Platinum
Speaking of H6 carbs, is there an advantage to installing spacers between HD6 carbs and their manifolds,
such as those shown (in black) in these pix?
red57
Steve is right that the float bowls are further from the exhaust manifold.
Also, Moss (page 27 for HD6 part number 696-000) calls them "insulating block" rather than spacers. Moss also shows on the tri-carb an "insulation block (1/4" thick)" and on the HS6 found on the BJ7 two of these "insulator blocks" at each carb.
I can't offer any citation but I have always understood they were an attempt to limit direct heat transfer to the carb body.
I have usually put as many as I can fit (even to the point of using longer studs) and still clear obstacles in the goal of keeping the carbs as cool as possible.
Dave
Editor_Reid
Editor_Reid
Platinum
Just by way of follow-up, we found that the cold air box would not fit with the spacers ("insulating blocks") installed. I suppose that the special shroud support bracket could be modified or removed to make room, but instead we are opting to go without them.
Very interesting that the Moss kit includes the blocks/spacers. Perhaps their shroud support bracket is already re-engineered to make it all work?
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
MGTF1250Dave SU H6 Carb, Float Bowl Mounting Bolt Triumph 2
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
