Spitfire 1500 gearbox question
recordsj
I have a 1500 mg midget (same gearbox as the 1500 spitfire) and have the transmission apart and have a question if you could help me with.
There appears to be be a lot of slop in the 3rd 4th synchromesh which exposes the detent ball, see picture in link below.
https://drive.google.com/open?id=1Ab3d5J6wjea--xCyCcdaCCcKaqYtMkKO
I removed the input shaft and measured about 3/16 of spline exposed from the synchromesh, when you rebuilt yours in the video, did you notices that mush exposed spline? See picture of it in the link below.
https://drive.google.com/open?id=1vmRQW1qcUF_GLxQHKxXibWp8Kak6gHZv
CJD
I am not familiar with the 1500 tranny...but it is not normal to have the balls exposed like that. Normally there is a C-clip on the end of the mainshaft, to prevent the gear stack from sliding around...and there is never that much room between the shifter hub and the clip. It looks like a spacer is missing in the stack.
I don't know if it is a factor, but often the synchro hubs have offsets. They can be installed backwards and it affects the spacing significantly.
R 1500 gearbox question Spridgets 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
Morris 1500 gearbox go clinky-clinky Spridgets 0
mdionne 1500 Gearbox Repair Spridgets 14
mdionne 1500 Gearbox Repair MG 2
R 1500 gearbox, trouble shifting into first from neu Spridgets 20
S 77 Midget 1500 gearbox Spridgets 4
R 1500 gearbox rebuild Spridgets 3
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
