For Sale TR 2, TR 3 TR 4 cylinder head
jfcdo
For sale here is a cylinder head for a TR 2, TR 3, TR 3A, TR 3B or early TR 4.
This is a high port head and it does not have the cut-away as the TR 4A heads had.
I do not find any numbers stamped on this head, so I have no idea what year or model it came from. 0502201138a1.jpg0502201138b1.jpg05022011391.jpg
This head has new valves and new valve guides. It's in very good condition, but needs a little cleaning up.
The head was mic'd and it measured 3.285, with 3.30 as the original.
Asking price is $600 (or best offer), plus shipping which could vary from $50 to $80 depending on how far it needs to go.
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B General Tech Cylinder head costs MG 7
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
K TR2/3/3A Cylinder head valve springs? Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
BOBBYR Cylinder head for sale on ebay Austin Healey 2
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
S TR2/3/3A Cylinder head stud methodology Triumph 11
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
B BN2 Cylinder Head Stud Thead Size/Replacement Austin Healey 0
TRspitfirefan TR4/4A Cylinder head issues? Triumph 5
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
