Aftermarket heater/defroster with 3 speed fan
HealeyPassion
How I spent 3 weeks during coronavirus self-isolation. Have you ever been disappointed in the heater/defroster in you AH? Cape Int'l sells a nice modern replacement, but unfortunately I was using some of that space for the ECU on my EFI build. So, I went to Vintage Air for a solution. They sell a small modern heater/defroster unit that looked about right. The original pathetic one speed fan is now deleted... replaced by efficient 3 speed fan feeding on "recirculated" air. Unfortunately, the nice 3 speed fan sits on top of the heater core unit. That made it too tall for under the dash of my Healey. The fix for that was to relocate the fan to a new location and fabricate a plenum on the heater core unit. In my experience, the package tray has way more room than I ever need for the few things I usually take with (sunglasses and phone), so I commandeered some of that space for the fan. I also put a trim plate in front of the new plumbing... the trim plate has a twin USB plug in which will come in handy when powering my laptop to tune the EFI.
1 AH Heater Core and Fan.jpg 2 AH Heater core with collector box placement.jpg 3 AH 3 speed fan 3 unit.jpg 4 AH Heater Core mounting frame.jpg 6 AH Htr core w plenum S50 1051.jpg 7 a AH Htr core w plenum S50 0966.jpg 7 AH Htr core w plenum S50 1053.jpg 10 AH Htr plumbing S50 1011.jpg 12 AH Htr Assembly w trim S50 1049.jpg 7 b AH Htr mount S50 0953.jpg
HealeyPassion
HealeyPassion
Lin, here is the Vintage Air Heater Defroster as it comes packaged from them. The 3 speed fan is easily removed from the heater core with a few screws. The unit has 3 modes.... full heat, full defroster and half/half heat/defrost... and the heat is regulated by a rotary dial.
15 AH Htr Def Vin Air S50 1107.jpg 16 AH Htr Def Vin Air S50 1110.jpg 17 AH Htr Def Vin Air S50 1111.jpg
HealeyPassion
HealeyPassion
I should add that the unit comes with three knob control. While it would certainly be adequate, it is plastic, since I was deleting the need for the original heater/defroster controls, I decided to fabricate a metal piece that would fit in the original location. I don't have a bunch of fancy tools, so this is how I did it. I used 2 3/8" plates to make the form, sandwiched 16g metal between them, hammered the metal into shape, welded and smoothed the edges... done. Now I'll have it powder coated in wrinkle finish. It will fit in the curve of the dash occupied by original htr/def. controls
1 Htr cntrls 16G S50 1077.jpg 2 Htr cntrls bld S50 1078.jpg 3 Htr cntrls bld S50 1079.jpg 4 Htr cntrls bld S50 1085.jpg .5 Htr cntrls bld S50 1080.jpg 6 Htr cntrls bld S50 1104.jpg 7 Htr cntrls bld S50 1116.jpg
HealeyPassion
HealeyPassion
John, can you share some specifics on how you made this? Pictures of build? Looks a bit like what Gary Hodson did.
Steve
John Turney
When we were at the 2017 International Meet in Monterey, my wife dragged me over to Gary Hodson's car and said; "I want this!" Since she is SHMBO, I took photos, talked to Gary, got some sketches and a copy of Gary's article in Healey Marque and a few others.
So, yes, Gary's car was the inspiration.
BoyRacer
Steve,
I'm confused. I see 2 pipes coming out of your plenums. Is one for outside air?
Richard
maxwedge5281
i put one of those heater defroster units in a kit car a few years back they are easy to install. controls are prewired and operate water valve and blower speed. and, the defroster works excellently1 i have another unit to put in my bn6 nasty boy primarily for the defroster....not sure i will need much heat. highly recommend especially in limited space.
HealeyPassion
HealeyPassion
Steve,
Richard
Richard, the 2 pipes for the plenum are both inputs from the 3 speed fan... the fan (blower) output volume would require a larger inlet than I could put in the space so I put in 2 outputs/inputs to handle the volume the fan puts out. I hope this helps.
Steve
Patrick67BJ8
What issue of the Marque was Gary’s article in? Thanks
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
roscoe Aftermarket Seats with Headrests Austin Healey 9
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
Y MGB Aftermarket wheels MG 5
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
kodanja TR2/3/3A Aftermarket Sun Visors? Triumph 12
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
Z TR2/3/3A Windshield Aftermarket Triumph 22
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
B 100-4 Aftermarket Hardtops Austin Healey 7
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
S TR4/4A aftermarket choke cable Triumph 3
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
W TR6 tr6 horn aftermarket Triumph 1
T TR6 TR6 aftermarket rear shocks Triumph 35
NutmegCT Aftermarket a/c? Restoration & Tools 15
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S TR2/3/3A aftermarket trunnions? Triumph 6
R Installing an aftermarket brake servo kit Austin Healey 6
F Thoughts on aftermarket air cleaners? Austin Healey 12
J aftermarket sheetmetal Spridgets 2
66healey Aftermarket brake booster pictures Austin Healey 7
Gray_Cat Bugeye Aftermarket Steering Wheels Spridgets 15
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
Branson Aftermarket wiring harness + original sprite wire Spridgets 5
R Red, white and tan covert tops aftermarket 60's? Triumph 11
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
RJS Aftermarket Cooling Fans Triumph 3
W TR6 TR6 aftermarket headers Triumph 26
newmexTR3 TR2/3/3A Aftermarket headlight relay mounting options TR2-4 Triumph 5
S MGB Aftermarket starter for 66 mgb MG 9
King_of_England aftermarket gear reduction starter failure Triumph 10
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
Don_R Aftermarket Steering Wheel Triumph 7
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
R TR6 TR6 Aftermarket Seatbelts Triumph 4
Editor_Reid Rare 100 Aftermarket Accessory Austin Healey 7
rustbucket T-Series Original vs. Aftermarket Cutch MC & Slave MG 4
71TR6 TR6 Aftermarket TR6 Steel Wheel Triumph 3
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
AUSMHLY Survey - stock, hybrid, aftermarket steering wheel Austin Healey 37
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
v8mgbal aftermarket steering wheels Spridgets 19
B Aftermarket Radio Install Spridgets 28
