Exhaust Fumes in the Cockpit - BT7
fishyboy
Hi all,
The other day I drove by BT7 without the tonneau cover (which is unusually for me) and with the two rear seat pans removed (which I've never done before). Driving at 60 mph on a local dual carriage-way the exhaust fumes coming in to the cockpit were extremely strong. Much stronger than when I normally drive the car, when I am always aware of exhaust fumes, but certainly not as strong.
When I got home I could find no leak from the exhaust and I don't think it's coming from the front of the car (I've tried to block any bulkhead holes and filled any gaps in the area around the transmission tunnel).
Posts on this and another forums suggest that it might be related to a some form of boundary layer that creates a back-flow from the rear bumper to the cockpit. Would the absence of the seat pans and tonneau exaggerate this effect, bringing more fumes into the car?
It was also suggested that the rear tail pipes should ideally extend in excess of 1 inch beyond the bumper. Mine (SS) don't appear to extend far enough (photo).
Should I try to buy/make a couple of small extensions to the tail pipes? Would these reduce the fumes in the cockpit once I get the tonneau and pans back in?
Phil
steveg
Phil,
My car used to stink when my engine was tired - IIRC it was worse with the top up and no side curtains. Since the rebuild, not much at all.
Driving with the seat pans out is not normal and may cause a vacuum sucking exhaust forward under the car; suggest re-installing those and taking it for a drive. Leave the tonneau off.
If still unsatisfactory, suggest adding the kind of exhaust tips that clamp on so you can adjust them out only as far as necessary.
NutmegCT
Seems that as air underneath the car is compressed by the car moving forward, any hole over that compressed air would act as a vacuum port - pulling air from under the car up through the hold.
Exhaust-filled air from engine and exhaust pipe area passes under car *until* it gets to the missing floor pan area. Result: exhaust fumes rise up through the hole.
Just my two cents!
Tom M.
F
fishyboy
Hi all,
Thanks for all the replies.
I am sure having the pans out and no tonneau on has made things much worse and when the weather improves (this in England so make take a while) I'll check out how things are with them back on the car. However, I could still smell the exhaust (but not half as strong) with all of these back on the car in the past ,so I'm going to buy some 6" SS extensions (which I will cut down to a reasonable size) and see what difference, if any, they make. If they work I'll have to find a more permanent solution.
In the meantime I'll keep checking for leaks!
Thanks all,
Phil
F
fishyboy
Hi all
I temporarily fitted the SS extensions. Not a very elegant solution i gant you but should go some way to see if the tail pipe leg nth is part of the problem. I couldn't fine and 36mm ID SS tube this side of the pond hence the exhaust brackets. These are 38mm ID.
Should I cut the ends at the same angle as the originals (first photo).
Phil
LarryK
Fumes are dragged through missing pans. Cover and try again as John said earlier before cutting or adding anything to exhaust. Jaguar had this on the XJ6 with straight exhaust is why the made the curved ends. Not your problem just car plling fumes under and thru floor.
Tosh Cockpit exhaust fumes Triumph 65
T Exhaust Fumes ?? Austin Healey 18
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
AUSMHLY Exhaust leaks Austin Healey 14
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
