TR2/3/3A Control Head/Stator tube orientation
BobbyO
I'm confused, which seems to be a natural state lately. According to the service manual and what I've read on other threads, the slot in the stator should be at 12 o'clock; however, when you look at the dimples on the control head stem from behind they are at about 4 o'clock. I thought those dimples were suppose to go in the slot in the stator and would hold the turn signal cancellation in place for it to activate after a turn. I have a second control head stem and the dimples are in the same place on it. Where am I wrong??? What are each of their orientations? Help!!!
TuffTR250
Here is the correct orientation:
TR3driver
Great Pumpkin - R.I.P
Sounds like you've got the base plate attached to the head wrong. But it really shouldn't matter. Leave the gland a bit loose, get the dimples engaged in the slot, then turn the head and stator tube until the turn switch is where you want it. It's a lot easier to judge the position of the slot that way, anyway.
B
BobbyO
Thanks Randall. It will be a lot easier to orient the stator tube to the dimples than change the base plate attachment. It's always easier to blame a PO but this car has so many things I'm finding wrong there's nothing else to do. The next thing is to remove the stator tube because it must have been built by the PO and the slot is only about 1/32 inch. I can barely see there is a slot. In fact, I busted a control head removing it because it had been jammed on. The one I'm using is one I've had for years, again from a PO.
karls59tr
I'm having a similar issue. How wide is the stator tube slot supposed to be?
B
BobbyO
I have an old one and it measures 1/8 inch. Don't have the length because the one I have is for the adjustable steering wheel.
TR3driver
The one I measured the other day was a little less than 3/32" (.085"). Length depends on whether you have an adjustable or fixed wheel. The one I measured is for a fixed wheel, slot is about 1-3/4" long.
B
BobbyO
I have good news and bad news. I removed the stator tube and it appears when the control head was forced on it squeezed the tube thus showing the 1/32 slot With the tube removed, I agree with Randall, it seemed to measure 3/32 X 1 3/4 inches. I was able to open it to 3/32 all the way. That's the good news. The bad, looking at the end of the slot, it has started to crack with about an eighth inch crack on each side. So now the question is should I just use it and hope for the best or replace it while it's out??
B Stator/Traficator [Control Head] Question Austin Healey 2
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
bluemiata90 TR2/3/3A TR3 Horn,control head and stator tube removel Triumph 9
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
71TR6 TR2/3/3A Control Head horn contact Triumph 7
Lin Another Trafficator/Control Head Question Austin Healey 10
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
C TR2/3/3A Control Head Rebuild Help Triumph 1
Got_All_4 TR2/3/3A Control head wiring help Triumph 11
C TR2/3/3A Control Head wiring Triumph 18
trotti Control head / trafficator questions Austin Healey 14
J TR2/3/3A Correct trafficator control head? Triumph 4
K TR2/3/3A The Control Head on the Steering Wheel Triumph 3
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
G TR2/3/3A Control Head How to Repair Triumph 5
G TR2/3/3A Control head Lubricant? Triumph 3
Y Fault in Steering Wheel Control Head in BT7mk1 Austin Healey 3
G TR2/3/3A Control Head Video Triumph 3
R trafficator/control head rebuild Austin Healey 10
luke44 TR2/3/3A Control Head Ground? Triumph 1
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
B Another wiring question 57 smallmouth control head Triumph 2
Superwrench Steering Control Head Assembly Austin Healey 4
Tinkerman 60 TR 3 A Control Head & Steering Wheel Triumph 9
S control head canceller 180 out Triumph 3
J TR2/3/3A TR3A control head question Triumph 4
tmc TR2/3/3A TR3A control head disassembly Triumph 4
DavidChandler TR2/3/3A Tr3A Control Head Triumph 16
K TR2/3/3A Internal view of a tr3 control head Triumph 7
Gordon_Dedrick Control Head Screws Triumph 5
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
AweMan Control head question Triumph 4
donbmw link to control head rebuild Triumph 5
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
P Steering Control Head Triumph 2
G Adapting adj. wheel control head to non adj. wheel Austin Healey 5
