TR2/3/3A Cracked Welds on Steering Idler Arm
mastaphixa
Bronze
After bead blasting my steering idler arm prior to powder coating it, I happen to inspect the welds that hold the arm to the shaft and found cracks in both welds. The image provided is not of the arm in question, but for reference only. I vee'd out the cracks and re-welded the arm/shaft as well as adding additional beads. There was no apparent deformation of the arm or shaft. Just a heads up for everyone.
sp53
Those are often wore out inside, and IMHO a weak spot on the car. Check it for wiggle; it should not have any. Probably replaces that.
M
mastaphixa
Bronze
Thanks CJ. SP53, this one is nice and tight, otherwise I would have just replaced it.
STeve 1958
I also have a 58 TR3A 32847 and had a 60 TR3A. Thirty-five years ago I had the front end rebuilt on my 1960. When I drove it home I felt like it didn't handle any better than before. Then I got a call from the shop saying "Don't drive the car" The mechanic showed up at my house a few minutes later with the idler arm bolts in his hand. Drove great after that. Apparently those idler arms are over rated. ;-)
TR3driver
Great Pumpkin - R.I.P
Must be my eyes, I don't see any cracks. Typical ****ty tack welds (which are just reinforcement for a press fit), but they don't look cracked to me.
And I agree with Steve, the idler doesn't do much.
P Cracked windshield Other Cars 0
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
P TR2/3/3A Windshield Cracked Triumph 12
Kleykamp TR2/3/3A Cracked Block??? Triumph 6
D MGB MGB Cracked Cylinder Heads Question MG 4
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
TimK 2 cracked windshields Austin Healey 13
aeronca65t Cracked Rostyle Spridgets 6
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
MCNX_BFF Cracked and leaky Triumph 20
M cracked head ??? Triumph 6
Carlos TR4/4A TR4A cracked cylinder head Triumph 8
Stewart cracked head? MG 7
tweety It wasn't a head gasket or anything cracked..... Spridgets 1
tweety I'm assuming head gasket, cracked block or head??? Spridgets 4
eschneider MGB MGB sunvisor rivets [and now cracked glass] MG 4
Baz Cracked coil spring! Spridgets 25
SilentUnicorn 1500 Cracked head? Spridgets 3
B Piston is cracked MG 7
U cracked exhaust manifold Spridgets 19
G TR2/3/3A TR3A cracked frame Triumph 3
J cracked wishbone! Spridgets 17
J New Soft-top, or reupholster cracked window? Triumph 6
G Quarter Light Frames Cracked! MG 0
M TR2/3/3A Cracked TR3 block... Triumph 0
N TR2/3/3A TR-3A cracked exhaust manifold Triumph 8
M TR6 Help- TR6 rear shock mount cracked Triumph 3
aeronca65t Cracked WIndshield Restoration & Tools 15
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
B BE floor pan welds aren't everywhere? Spridgets 2
CJD TR2/3/3A Drilling spot welds Triumph 9
M Look at my welds! [pics] Triumph 23
O TR2/3/3A Help with TR3 inner sill removal - blind welds? Triumph 5
B Ugly welds Restoration & Tools 13
B TR2/3/3A Question about bad welds on frame 57 TR3 Triumph 6
T Will this work on MIG welds? Triumph 10
beaulieu drilling out sheet metal spot welds ? Restoration & Tools 11
74WannaB infinite spot welds MG 5
L Separating Sheetmetal Welds Austin Healey 9
A Flanging tool for lap welds Restoration & Tools 5
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
