T-Series first gear alignment
saltiga
MG TD this is the alignment of the first gear cant see it easily when fitted as lay shaft is under and difficult to see. the first gear wear indicates this is how its been meshing is this normal if not whats the cure?? saltiga
PAUL161
It looks like fist gear is sliding too far forward and overshooting it's mark. Is the fork adjusted where it's supposed to be on the selector shaft? Hard to diagnose without seeing it in person. PJ
S
saltiga
My sons name is Paul so you must be a good bloke. The first gear is not going far enough to the right for full engagement i dont have another gearbox to compare the fork position with.( I have contacted a guy who says he has an mg y box and hope then to compare with) I will post pictures of first gear, neutral ,then in 2nd Saltiga
S
saltiga
Paul I have just looked at the pictures and in the first gear position its possible to see where the gears have been meshing there is a darker area to the left on the first gears at the mesh point Saltiga
Platinum
As Paul states, it's hard to analyse it without a hands-on inspection.
Looking at the wear pattern on both first gear and layshaft, it appears that it's been running like that a long time. Position on the mainshaft is determined by the cut-out position on it for the detent balls in the collar. My WAG (Wild Arse Guess) is it's been like that from the beginning. I'd replace the bronze fork(s) and press on. But it's been so long since I've been in a T-series box I don't recall if that's how they are normally. If you get to eyeball another unit, you'll have a better idea of what's "normal".
S
saltiga
Yes I am thinking along those lines all i need is another g/box which i think is coming or a kind TD owner to measure theirs. It does not surprise me if the indents are out. When i recond the oil pump on the engine the slave gear (a new one) would not fit in the opening, the body had been machined .005inch smaller than the driven gear opening , the easy way out was to tale .007inch off the gear fitted together and now have 60lbs at idle and the pressure relief must be working at 65psi saltiga
PAUL161
First gear is held in place with the fork, it doesn't have an interlock (spring loaded ball), I agree it's been that way for a very long time and possibly since new. These things were pretty much put together by hand so a miss alignment might have been in there from the beginning. I need to look at a exploded view of the transmission. PJ
PAUL161
Make sure the stops and fork are in the proper position on the shaft, like I said before, it's tough to to analize without having it on hand. Now saying that, for as long as it's been that way, I wouldn't worry about it, just drive the heck out of it! :encouragement: PJ
Platinum
Apologies! As stated; been too long since a T-series crossed the bench. Looked at an MGB 3-synchro box diagram, it's the same... I'll claim oldtimers' disease.
...but would still say replace the fork(s), Laygear bearings and if galled, the layshaft, along with remaining bearings/seals then re-assemble and drive.
PAUL161
I agree Doc, having it down this far, a complete rebuild would be the way to go, but now until things get straightened out on this Chinese virus thing, some folks might not want to spend that kinda money and keep it in reserve. Different strokes!
S
saltiga
The 1st /2nd gear fork is made of steel, mine has a .010 clearance.and can be built up with weld. the first gear is held in by the fork and the ball and spring on the shifter shaft, the fitting of another spring , ball and another indent into the 1st/2nd gear shifter shaft will also help. the position of this is in the machining hole for the interlock balls between 3/4 and 1/2 shafts. I have a suspicion that the out of alignment of the first gear will tend to wear the teeth on first gear into taper as evident on this gearbox it also wears the first/second slider as evident in the slider gear spline. now if this is the case then jumping out of first gear will be more of a possibility. the gear wearing in the center will tend to leave a shoulder of unworn gear helping it to stay in gear this of course is supposition. A close look at the first gear teeth shows this taper the best I can measure its about .020inch, the wear on the slider shows the first gear has been a sort of rocking motion also adding to first gear jumping out of mesh
Platinum
Okay, seeing those pix it appears the incomplete engagement has tapered the teeth of the first gear, I'll assume the laygear exhibits the same? That doubles the angled load as result. That would effectively induce a sort of side-load on the gear, inducing the "rocking motion" you describe. Wear on the shaft splines worsens, the ramp effect increases and the result is popping out of first gear on load.
None of that is good news.
S
saltiga
Yes, the lay-gear is also tapered, its hard to measure but i have about .005inch taper wear on most of the teeth. My thoughts are, if this is common with td/tf gearboxes its why many complain of first gear problems i have the MG Y box now but the first gear and lay-gear are missing. Can any one give me the measurement of the neutral to first gear selector shaft indents, mine measure .670inch This is also hard to measure accurately but its in the ball park. I will be replacing lay-gear, first and slider. Has any one used the rebuild lay-gear?? Saltiga
L T-Series Gear box servicing cap. MG 5
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
Joe Reed MGB Dropping out of 3rd gear... MG 2
J Planetary Gear Removal Austin Healey 3
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
R TR6 Gearbox slips out of 3rd gear Triumph 14
