TR2/3/3A door capping with buttons
DavidApp
Having problems getting the clip thing into the rubber core?
I drilled a hole then a soldering iron to enlarge it as the rubber did not drill well. Seems to be holding. It was a PITN.
David
S
sp53
My problem is with getting the capping on after I upholstered it. I used some foam- backed material product, and it made the pieces too tight/large to fit the door top; too many folds of vinyl, material, and foam. I did a real nice job too. Last night I ripped one apart and I am going to start over. I have experienced in the past that the vinyl can pull out from the fold on the under the trim, so I wanted it hold, but too thick. This time I will leave off the fold on the edge that faces in the car and stop the foam there also and just have vinyl on the outside folded under. I am doing something different on the ends also, but not there yet.
DavidApp
Seem to recall I had to do some trimming of the vinyl covering. I think I feathered the ends to minimize the amount under the button. Do not know if I took photos or was too busy getting it done.
David
charleyf
I just completed my set but with leather. Sorry no pictures.
The first thing I noted was that I had to drill a hole in the foam roll to make room for the base of the chrome button.
When cutting the material to fit into the end I cut the material in what can be described as VVVVVVVVVV. Just be sure to not cut the material to deep. Leave enough material to not show any cut exposed above the chrome button.
I hope this helps and is not redundant.
S
sp53
I got a glimpse past the lunatic fringe after I started over with the door capping. i am happy with how the cockpit capping came out so far and I would like to thank David for his idea of burning a hole in the rubber. I used an old drill bit with some vise grips. As far as bring all those pieces of vinyl and ending them at the button and having the overall piece stay small enough to fit the door correctly took some trial and error. I basically pulled the vinyl over the end and down both sides gluing as I went in stages then gathered the vinyl at the center under the capping piece leaving a seam at the bottom so the seam would be hidden. Sounds easy.
TRopic6
Yes, your trim looks smooth and professional. I couldn't find these in time to help, but at least you can confirm your end-cap look. These are original leather door caps I took off a junkyard car in the late-80s (remember those?). P1110559.jpgP1110557.jpgP1110558.jpgP1110560.jpg
Rut TR4/4A Door capping Triumph 7
B Door Capping on a TR3 Restoration & Tools 0
PeterK TR2/3/3A How do I remove TR3 door capping Triumph 6
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
T Heater Door Spring Austin Healey 1
