TR2/3/3A Removing Wires From Stator Tube
mastaphixa
Bronze
I have my stator tube removed from my steering shaft. I see the little Chinese handcuffs i've seen discussed here. My problem is the wiring is still in the stator tube. There's nothing to grab onto to pull it out. Can anyone offer a suggestion or maybe share some experience with this?
Regards,
Steve Baker
M
mastaphixa
Bronze
Tom,
Thanks for the link (and I did read that one before hand). That thread deals with how to pull the harness in or out. My problem is the wires are in the tube with nothing hanging out to grab onto to remove them.
Please post of you get them out. I have a tube like that. Thinking about burning the tube to make wiring cloth crumble and easy to pull out.
Marv
M
mastaphixa
Bronze
Well it was not a very elegant solution, but I welded a 3/32" extension bit to a length of 3/32" piano hinge material I had, chucked in the drill and just kept drilling into the wiring. I worked from both ends and for the first 45 minutes I really didn't think I was getting anywhere. Then chunks of insulation and copper started coming out (and wads of electrical tape). I finally got all the wiring out. I'll make a butterfly to clean the bore up completely tomorrow, but I think I saved it!
NutmegCT
Wow - what a pain, and what a mess, but you figured it out.
How on earth would anyone accomplish the task without the destruction.
Congratulations - you're a better man than me!
Tom M.
CJD
So you drilled it out...interesting idea. I wound up chucking the tube and making a new one because the wires were so stuck.
DavidApp
Looks like you had mice nesting in the tube. (Tiny mice)
Congratulations on getting it cleared out.
David
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
Tinkerman TR2/3/3A Removing old contact cement Triumph 6
