Sump Plug
mgtf328
Can anyone please tell me what size spanner fits the sump plug? I have a pretty good collection of spanners but can't find one to fit. The plug is pretty well chewed up already so don't want to put an adjustable on it and make it worse!
Thanks
AJ
M
mgtf328
Thanks guys. I tried 1-1/8" - too small. 1-1/4" too big! I thought it might be some weird metric/BSF/Whitworth size and I don't have them that big.
I need to take a closer look. Maybe it's just a bit chewed up but it's hard on my 70 year old body crawling underneath to get close enough to see!
I'm afraid that if I get it off with an adjustable spanner I may chew it up up even more and won't be able to tighten it enough to stop it leaking when I put it back.
AJ
bob hughes
It will be possibly the one in the middle then :emmersed:
I am trying to find my new magnetic plug that I bought years ago, to go with the new sump that I had bought back in 2013, do you think that I can find it? !
:cheers:
steveg
Guys - I bought an aluminum sump maybe 15 years ago. It does not use a stock plug. I had bought a magnetic plug that didn't fit - at time of purchase assumed the aly sump took the same plug. I took the magnet out and drilled/glued it into the new plug.
Here's the plug - 28mm wrench:
Here's a spanner from eBay UK; 28mm socket's about the same price:
steveg
I did the same as you, Steve, and used my calipers to measure the hex. 28 mm was too small.
John - Sounds like the takeaway is everyone should measure their own and proceed accordingly.
Getting the right size wrench on eBay is often pretty cost-effective.
Healey Nut
Having served my apprenticeship in the UK I do still own quite a few BS and Whitworth spanners , open ended and ring type .
The one I use for the sump plug says 5/8W / 11/16 BS on it . It is very slightly sloppy but the sump plug is a little worn as well .
bighealeysource
Bronze
Hey Guys,
Kinda on the same subject about sump plug. I cannot get rid of a minor leak - drips - from my sump plug. Believe I even changed it out with a new one from Moss but still will mark its territory. I do tighten it as much as I dare and have even tried putting on some teflon take taking care that none gets inside the sump. Still minor drip. Any suggestions ?
Thanks
Mike
red57
You might try annealing the copper washer, they 'work harden' after several uses and benefit from softening, or get a new one. Also, check for any burrs/mars on the sealing surface of the pan & plug that would prevent sealing.
Thread tape won't help because it isn't a tapered thread, the copper is what seals it.
Dave
bighealeysource
Bronze
Thanks guys ! I purchased a new one from Moss but size seemed too large. I kept my old one and will try heating up like Steve suggested !
twas_brillig
Two thoughts: would coating the plug with anti-seize compound fill the threads/etc. better than the teflon tape? And I stick a rare earth magnet on any and all ferrous drain plugs (diff, trans, engine), plus on the ends of all spin on oil filters, figuing that it might help collect debris. And they're relatively cheap so long as you remember not to lose them. Doug
Michael Oritt
AJ--
You said "I'm afraid that if I get it off with an adjustable spanner I may chew it up up even more and won't be able to tighten it enough to stop it leaking when I put it back."
Even if you have to use an adjustable or pipe wrench to remove it you can then grind down the flats so that 1-1/8" is a good tight fit.
steveg
Thanks guys. I tried 1-1/8" - too small. 1-1/4" too big! ....
AJ
I've found that on eBay it's possible to cheaply buy an odd-sized spanner or individual socket so that one has the right tool for the job.
steveg
I've had to make do with too-large ones. Sometimes you can put an o-ring in the center to help center the washer.
OZ_BN1 Sump Plug Austin Healey 0
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
WHT Oil Sump Question For Dougie Austin Healey 0
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
Lin Oil sump sealant question Spridgets 0
Lin Oil sump torque value? Spridgets 3
Walter74 Oil sump AH spares Austin Healey 5
M Sump Installation Spridgets 2
F Sump Gasket Question Austin Healey 15
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
Lin Oil sump gasket replacement Austin Healey 31
Healey Nut 3000 oil sump pans Austin Healey 16
R Proper Aluminum Sump Installation Austin Healey 13
Michael Oritt Strange debris found in sump Austin Healey 19
J TR6 Thrust washers in sump Triumph 4
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
Dudly Sump and timing cover gaskets Triumph 1
TomMull Sump pan with no baffle? Triumph 2
abarth69 Dry Sump BMC Engine Spridgets 3
T XK Engine Sump Pan Jaguar 9
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
Westfield_XI Evacu-sump installation Spridgets 5
Westfield_XI Evacu-sump installation questions Spridgets 4
newmexTR3 TR 2/3/4 aluminum sump gasket Triumph 4
B Oval sump washer orientation Austin Healey 2
2wrench Help. Leak from sump cover on bottom of J-OD Triumph 31
Scott_Hower MGB MGB sump removal .. must I drop the xmember? MG 13
J Can I drive with dipstick pipe in sump? Spridgets 6
philman Wedge TR8 oil sump pans Triumph 2
TRclassic3 TR2/3/3A TR3 Oil Sump Gasket Question Triumph 3
M XK 140 Sump color Jaguar 4
cjm dry sump system Triumph 8
dkj313 MGB Sump Gasket 76 MGB MG 5
J TR4/4A Aluminum Sump made for TR3-TR4? Triumph 15
Lin Oil Sump gasket dressing [sealant] Austin Healey 3
Dave Russell Experience installing new oil sump Austin Healey 2
bighly Magnetic sump plugs / tranny plugs Austin Healey 0
P Oil sump capacity Austin Healey 7
bighly Sump [does 1 size fit all?] Austin Healey 1
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
