My 58 is a non running car at the beginning stages of restoration. The steering exhibits a noise and vibration best described as an EEEEE EEEE EEE whenever the wheel is turned. With the front wheels clear of the ground same thing. After disconnecting the drop arm the wheel moves very smoothly and quietly from lock to lock, but with a good bit of slop. I pulled the single piece adjustable wheel steering column and proceeded to get into the steering box. Upon removal of the steering shaft and cleaning up the worm there is damage to the worm, but I am not sure of its significance. The peg is quite worn (I'll include images of it in a reply to this post) but smooth. Clearly the peg should be replaced. Obviously my main concern is the worm. Please gaze at this rascal and let me know what you think.
Regards,
Steve Baker
Regards,
Steve Baker
