Started adapting the datsun gearbox today
Bayless
This is not gonna be a one day project. The Rivergate instructions are pretty clear when you have the bits in front of you. We got most of the modifications to the box and adapter done today (we only work half a day at a time). The next step is install the plate to the motor so that is tomorrow's job. Not sure but it looks like we might be able to get it in the car next week. Also working on some minor rust in at least 1 of the front wings.
drooartz
Excellent!
I've got he Datsun box in my Morris Minor. That 5th gear is a really nice thing.
Jim_Gruber
And depending on your BE and the 210 adapter rear tranny mount you may run into a clearance issue with DS yoke hitting although slightly, just behind the shifter opening. I’ve run into that w Bugsy and my next project job will be some minor surgery w angle grinder and a cutting blade to the top of the tunnel. Plan is to cut a 2” x3” Opening so yoke can turn freely and fabricate an access panel that sits a smidgeon higher And either weld in place or secure with bolts. Carpet goes over the top and this mod will be unseen. I can attest that one rear mount I tried had the tranny/adapter plate sitting 1” lower than the other and over those long traffic calming humps that a BE straddles that the adapter plate dragged over that top. Now rear of tranny sits 1”+ taller and that translates into More ground clearance.
Now in the past, Frank C’s method for fixing this was to have car on jackstands and shove a broom handle into the top of the tunnel while the car was in gear and running to create more clearance. After reading about his fix and how tranny yoke chewing up a broomstick like a pencil sharpener seemed extremely dangerous to me. Taking a small piece of the tranny tunnel off and reshaping the top of the tunnel seems far far easier to do.
Bayless
Bayless
Thanks for the advice Jim. Mine is not a BE but a MkIV. That may or may not make a difference. Will at Rivergate swears there won't be any issues. We will see over the next week or two, I hope. I got some more advice from our local guru to drop the steering rack, also a reminder to install the speedo cable before installing.
Jim_Gruber
Should not make a difference but rear mount definitely does. And if it does interfere it is possible to fix it.
Pythias
I watched/helped Paul A do the broomstick trick on my conversion. He spear tossed the handle into the tunnel. It took a few tries as it's a timing thing, getting the U-joint to catch the stick at just the right time so that the stick was "trapped" as it went round and round beating the tunnel the out. Interesting thing to see, but seems easier to me than cutting and fabbing, especially if your carpet is already glued in. The most time consuming thing is putting the car on the 4 jackstands, but since you're already in the middle doing the conversion, that part is done already.
Another fix that may need done is because the shift stick doesn't come up in the center of the hole any longer. One method is to get the gaiter ring from a later car and use the leather gaiter instead of the (remove able) shifter can. I was lucky to know a guy who could weld. I had him cut 1" off the height of the can and fill in the hole. He then redrilled the hole effectively moving it forward. Got a rubber gaiter for an MGB and away I go.
YMMV
My 2¢
Jim_Gruber
Agreed on the MGB Gaiter. That's what I did. just leave the first 2 rings underneath the opening in the turret. And Bill since main wire harness is not installed yet, starting the engine and tossing in a broomstick is not an option. Carpet is not yet installed. And I'm assuming you did this on your MkIII Sprite.
Bayless
Bayless
There is some mention of the "later Midget"gaiter I think in the 11 pages of instructions. I'm a little confused on this issue. Are you saying to keep the can, maybe modified a little, and add the gaiter to it or ditch the can completely and put the gaiter directly on the tunnel? Also, the idea of tossing a broomstick in the tunnel is kinda scary. I will check the rear mount very carefully. It sounds like we may be fitting this thing twice.
Pythias
Using the later gaiter ditches the can. Have a look at the moss catalogue pictures and you'll see. It's probably the easiest solution. And, YES throwing the broomstick up the tunnel at the same time the clutch gets engaged, the resulting noise and pounding IS scary. The broomstick gets destroyed in the process. You may need two of them.. BOOM BOOM rumble rumble BOOM BANG BANG.
Stan Kowznofski
If I have to clearance the u-joint area when I get around to doing mine I think I'll make a removable access panel. I would think that would make greasing the joint a dream. I am also contemplating a small access panel on the right side of the tunnel so I can use the Datsun factory switch for the back-up lights. Any thoughts?
Rut
I like the original top hat and rubber...I also added a thin sheet of rubber below the top hat to prevent fumes from coming in.
Rut
BlueMax
I like the original top hat too, but found the shift a little stiff with the OEM boot. I enlarged the hole and used a MGB shifter boot.
Bayless
Bayless
I really like that solution.
Meanwhile, we got the plate installed but had a setback yesterday. It seems my flywheel alignment pins are missing. Our local pro gave me an old crank to try removing them from. We'll see how that works out today.
Rut
I built my own short throw shifter and put the gear lever dead center so it’s not stiff. They are very easy and cheap to build and you can put the shift lever where you want it.
Rut
Boink
Bronze
Gerard has some nice mods to make all this work (though the old Paul Asgiersson kit). He also had a way to pound out the tunnel in a bit of a more controlled way. :rolleye:
You might check the lengthy read on this ("5 speed vs 3.9 differential or both") I started a few years ago... though the conversion wasn't Rivergate. There are a number of photos there too that address fitment issues. http://www.britishcarforum.com/bcf/showthread.php?107334-5-speed-vs-3-9-diff-either-or-both&highlight=speed+3.9+diff
Jim_Gruber
His truck with a palm nailer and nail in backwards is a great trick as long as you know up from that you need additional clearance. Unfortunately with engine and tranny installed there is no room to work in there.
Boink
Bronze
I'd probably pre-emptively do it... as it's likely needed.
Bayless
Bayless
Well I managed to get the pins out of the old crank with a little, no a lot of, help from the oxy-acetelyne wrench and installed in mine. We reinstalled the flywheel and verified all the clutch to throwout bearing measurements. I believe it is now ready to mount the gearbox so maybe tomorrow. It looks like Thursday will be dedicated to getting some paint on the Model A.
Bayless
Bayless
I did paint yesterday. Today we made the first attempt at fitting the 5-speed into the Sprite. My partner insisted in adding everything as he "didn't want to have to take it back out to add that stuff". I prevailed. We left off everything possible for the "test fit". Sure enough, it didn't fit. With it tight against the rear cross member and the heater box with less than 1/8 inch clearance at the front cross member, it still needed to go back about 3/8 inch before it would clear. I pulled it out and took the grinder to the offending area of the bell housing for another 1/8 inch or so and we will try again Monday. I feel pretty confident it will go this time.
My rear mount is 2 pieces and it looks like I can modify it to sit a little lower if necessary for the u-joint to miss the tunnel. Also, I think I can modify the gear stick to center in the hole all right. Instructions claim I can add the speedo cable through the gear stick hole. We'll see.
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
J Finally getting (re) started on the Bugeye Spridgets 27
Tr3aguy TR2/3/3A Started a Car revival channel for the TR3 Triumph 12
T TR6 Car has always started without fail.....until now Triumph 10
J TR2/3/3A Finally getting started Triumph 20
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
G TR4/4A YAY! It started!!! Triumph 16
S TR2/3/3A Frustration has started but car wont. Triumph 4
HighAltitudeTR3 TR2/3/3A Just started burning some oil... Triumph 8
M_Pied_Lourd TR5/TR250 Started my TR250 Restoration Project..... Triumph 16
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
David Townsend Sprite Illustration Started Spridgets 31
David Townsend Sprite Illustration Started Austin Healey 7
David Townsend 100M Illustration Started Austin Healey 32
M_Pied_Lourd TR2/3/3A TS44836LO Resto Started Triumph 6
drooartz MGB-GT Conversion has started - splines to studs MG 51
jaegzie Long time since I've been here but progress has started. Bigeye rebuild Spridgets 9
Keith_M Bugeye Restoration Finally Started Spridgets 37
M My '65 suddenly started running bad today Spridgets 37
simon1966 Started to dig out the 100 Austin Healey 3
oxford New owner BN4. Work started . More questions. Austin Healey 13
T moved post from ZS 1500/started new Spridgets 4
I Help - can't get my bugeye started Spridgets 17
S TR2/3/3A TR-3 hard to start, but runs well once started Triumph 5
J Finally got my '56 started Triumph 3
R TR2/3/3A TR3A Finally started Triumph 6
Scott_Hower Hap started my head... Yay! Spridgets 13
rikiwho123 i started my 1300 Triumph 0
R MGA ITS ALIVE! MGA Started After Sitting 4 Years MG 1
I TR6 Getting a TR6 started again-where do I start? Triumph 9
M Project started-switching dash Spridgets 17
R MGB Getting started with the MGB - first questions MG 13
Nelson It started! Spridgets 5
J Rover engine that started as Buick? Rover / Land Rover 9
scoutll Car suddenly started running poorly Spridgets 17
doughairfield Trying to get my motor started Triumph 8
JPSmit It has started Spridgets 4
GregW Started working on the Healey again Austin Healey 12
pjsmetana Started instantly... without my choke! How? Why? Triumph 5
doughairfield TR4/4A HELP not able to get my TR4 started Triumph 104
6 got it started Triumph 4
M It started! Triumph 5
LastDeadLast Offically started my hardtop project - Question Triumph 5
Brosky Dash panel replacement page started Triumph 0
R '67 Midget engine started for first time in... Spridgets 9
JodyFKerr Finally getting started Austin Healey 1
2wrench MY CAR HAS STARTED....PICS/VIDS NOW WHAT? Triumph 11
B started a rebuild of a 62 sprite. HELP required! Spridgets 20
B started a rebuild of a 62 sprite. HELP required Austin Healey 1
