TR2/3/3A Ballast resistor to prevent hyperflashing
Jim_Stevens
I’ve shifted over to led positive ground turn signal lights using the original style Lucas flasher. I installed two 5-ohm 50W resistors to ground, one on each side, tapping in at the bullet connectors each side. I’m still getting hyperflashing and no clicking sound at the flasher. The resistors do get warm to the touch, so they are carrying current.
I pulled the flasher out and checked it with an incandescent 40W bulb, tested sat.
I’d have thought 5-ohms would have worked, but evidently not. A 3 or 4-ohm resistor may be needed to induce enough current to trigger the flasher. Anyone have any experience? Jim
TS 44743L “O”
TR3driver
Great Pumpkin - R.I.P
I had a hard time finding flashers that would work correctly with the stock lamps (and my original failed), so I haven't tried a resistor with the stock flasher.
But, spec is 21 watts per bulb, which if I've done my math right, works out to 3.5 ohms. Assuming a 50% duty cycle, that's an average of 20 watts at the resistor, so a 5 watt is going to get VERY hot.
Jim_Stevens
Jim_Stevens
Totally agree— using 50W! And will order 3.3ohm, 50W resistors straightaway. Jim
Jim_Stevens
Jim_Stevens
And just for future queries, I ran it with both 5-ohm resistors in parallel (2.5 ohm total) and he blinkers worked fine, so I’m assuming the 3.3ohm ones I just ordered will work out too.
Somewhat surprised that the 5ohm ones didn’t work, but live and learn once again in this humbling hobby!
Geo Hahn
I'm using a pair of 6 ohm 50 watt resistors with LEDs only in the rear lamps. Seems to work fine though sometimes the dash indicator flashes rather weakly.
Jim_Stevens
Jim_Stevens
No idea why your 6ohm resistors work whilst my 5ohms didn’t. That said, the new 3.3ohm ones came and I installed, and the flashers work fine again. on the dash, I’m using an LED bulb there too. Plenty bright!
NutmegCT ballast resistor Other Cars 10
A Ballast resistor Triumph 7
TulsaFred Ballast resistor Spridgets 28
regularman Ballast resistor mystery Spridgets 2
A ballast resistor 75 mgb FORUM Navigation Questions 0
A MGB ballast resistor 75 mgb MG 2
H Ballast resistor MG 9
RynoBoy74tr6 Ballast resistor location.... Triumph 10
newmexTR3 TR2/3/3A Pertronix on TR3 Ballast Resistor or no? Triumph 3
8 BALLAST RESISTOR???? Triumph 12
J Spitfire Spitfire Ballast Resistor Triumph 3
C Ballast Resistor Spridgets 34
B TR6 TR6 / Pertronix / Ballast Resistor / etc Triumph 13
RichC Primary Ballast Resistor Ignition? MG 1
R Link to Ballast resistor wireing Jaguar 0
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Marla TR4/4A Ballast or Non... Triumph 6
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
SilentUnicorn MGB ballast wire mgb 77 MG 2
T External ballast resistors - do they go bad? Triumph 8
john_j Coils and ballast resistors Rover / Land Rover 2
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
19_again resistor MG 2
J Tach resistor Spridgets 8
H TR6 tr6 heater motor resistor Triumph 0
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
1 MGB Any way to prevent rust on these MGB's MG 9
