TR6 Front Brake Caliper Bracket Part Identification
mastaphixa
Bronze
I am gathering parts to mount Toyota calipers on my TR3A. I have purchased what I hope are the correct caliper brackets (TR4A/TR6). I understand the stanpart part number I need for this mod is 133499 and 133500. I have attached 2 images of the brackets I received. My best guess at the numbers shown on the brackets is ILO8118ME1 and ILO8118MF1. They look right, but I can't cross those numbers in any of the searches I have done. Any help will be appreciated.
Steve Baker
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
bighealeysource Front Brake Adjusters Austin Healey 0
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
I Bug eye front disc brake conversion. Spridgets 5
bighealeysource Question on 100M front brake cylinder Austin Healey 4
John Turney TR6 Brake Line to Front Calipers Triumph 4
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
I Wanted Sprite front brake parts Spridgets Classified 1
T Assistance with Front Brake Lines Spridgets 3
doc50 Met front brake pistons Other British Cars 4
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
AngliaGT Front Brake Dilemma - '74 cb Midget Spridgets 4
R TR2/3/3A Front Brake Conversion Triumph 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
G Rover P3 Brake Lining - Front Rover / Land Rover 2
K TR2/3/3A Front disc brake squeal.... Triumph 4
L Front Brake 100/6 Austin Healey 1
R Help with BJ7 front brake line routing Austin Healey 6
A TR6 '73 tr6 passenger front brake dragging Triumph 2
F Front brake hose BJ8 Austin Healey 4
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
F front brake hose 67 BJ8 Austin Healey 4
M Front steel brake lines Spridgets 9
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
R BJ7 Front Brake disc hitting Austin Healey 12
P Bugeye front drum brake picture Spridgets 7
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
bigjones Front brake job - any advice? Spridgets 94
RJS TR4/4A Replacing front brake hoses Triumph 10
C question on the front brake lines for BJ8 Austin Healey 2
nevets Front brake hose length Austin Healey 10
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
BillD Bug Eye front drum brake question Spridgets 12
