Results 1 to 9 of 9
Thread: Dot 5
  1. #1
    Join Date
    Aug 2014
    Location
    Clermont, FL
    Posts
    267
    Blog Entries
    1
    Thanks Thanks Given
    2
    Thanks Thanks Received
    Thanked in
    Dot 5
    I am in the late stage of restoring a 54TR-2 Long Door. The brake system is all new, master cylinder, wheel cylinders, clutch slave cylinder. The steel lines were good, flushed good before re-installing. I have heard the pro's and con's of using DOT 5. Any suggestions, guys?
  2. #2
    Join Date
    Jun 2013
    Location
    Honolulu, Hawaii
    Posts
    208
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Dot 5
    Should go with DOT5. With all new braking system, one of the "cons" is eliminated as there is little to no chance of mixing fluids. DOT5 does better for vehicles stored for periods of time, and of course won't melt paint. I have had it in my Doretti and TR2 for years and no problems, both have firm pedals. Let the debate begin!
    Dan
  3. #3
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    229
    Thanks Thanks Given
    12
    1
    Thanked in
    1 Post
    Re: Dot 5
    Quote Originally Posted by Redoakboo View Post
    After I saw the mess that occurred over the years in the paint beneath the reservoir, I went with DOT 5!
    Before:
    Attachment 62977
    and after:
    Attachment 62978
  4. #4
    Join Date
    May 2012
    Location
    Robbinsville, NC; Everglades City, Fl
    Posts
    654
    Thanks Thanks Given
    10
    Thanked in
    Re: Dot 5
    I've been using DOT5 in my TR3 for 5 or 6 years. I have seen no "cons". The main "con" of DOT3 is that a paint sprayer is hard to get into the engine box when the fluid damages your paint, which it surely eventually will.
  5. #5
    Join Date
    Oct 2013
    Location
    Omaha, NE
    Posts
    132
    Thanks Thanks Given
    3
    Thanked in
    Re: Dot 5
    I've watched these online DOT3-4/5 debates for years. Opinions usually seem to favor DOT5 by a ratio of 4 or 5 to 1 and increasing.
    I use DOT5 and see no good reason to switch back.
    Ed
  6. #6
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,977
    Thanks Thanks Given
    17
    53
    Thanked in
    Re: Dot 5
    I've had DOT5 in my bugeye for about 30 years and still good (maybe time for a bleed and refill while I've got some spare time) Great stuff. Only disadvantage is a slightly spongier brake pedal than DOT 3 or 4, but nothing ridiculous.
    Rick
  7. #7
    Join Date
    Aug 2014
    Location
    Clermont, FL
    Posts
    267
    Blog Entries
    1
    Thanks Thanks Given
    2
    Thanked in
    Re: Dot 5
    Thanks Guys, DOT it is!
    Dick
  8. #8
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    Re: Dot 5
    FWIW, you can partially compensate for the soft pedal by converting to the braided stainless brake hoses. They swell less under pressure than the originals.
    I've lost track of just how long I've been using DOT 5, got to be around 35 years. I really like it and recommend it; unless you want to be absolutely original and have brake problems every year. That's one part of the "Triumph experience" that I'm glad to miss out on!
    Randall
  9. #9
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,548
    Thanks Thanks Given
    15
    21
    Thanked in
    Re: Dot 5
    I have posted this before, I have used DOT 5 for years, and have fewer leaks in the hydraulics, which used to be a more regular occurrence. No problem with mushy pedal or blessing. However after about 8 years I had a brake master cylinder fail. It wasn't the rubber, when I took it apart there was a line of corrosion straight down the bottoms of the bore.
    DOT5 doesn't absorb water, it sinks to the bottom of the mix. My fault for not flushing often enough, and I still use it, but in my mind that is the real issue with DOT5.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
