Results 1 to 5 of 5
Thread: Windscreen wiper wheelbox rubber shaft seal
  1. #1
    Join Date
    Mar 2016
    Location
    Birmingham, UK
    Posts
    3
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi guys. The rubber seals that fit over the wiper wheebox spindles on my BJ8 have perished and allow water to run down the shaft and drip inside my car so they need replacing. I haven't found any parts supplier that sells these but I have read on the MGA site of someone dismantling the wheel box to remove the shaft to replace it - I don't want to risk that but wondered if anyone else had obtained any rubber seals and just stretched them over the splined head onto the shaft, or achieved a seal some other way? BTW I'm not referring to the flat rubber gasket that fits on the shroud. Richard in UK
  2. #2
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,081
    Thanks Thanks Given
    142
    183
    Thanked in
    Re: Windscreen wiper wheelbox rubber shaft seal
    Got this from AHspares' site; added the red callout. Is that the seal? Not sold separately. They want you to buy the wheelbox.
    Looks like you'd have to pull the spline and add your own seal. Maybe some o-rings or pack it with waterproof grease.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  3. #3
    Join Date
    Mar 2016
    Location
    Birmingham, UK
    Posts
    3
    Thanks Thanks Given
    Thanked in
    Hi Steve, thanks for the reply. That is indeed the part in question but strangely it isn't available separately despite being an item that deteriorates over time and crucial to the fight against water ingress! I suspect that I'm going to have to find some suitably thicker rubber or silicone sheet that I can punch a hole in and slide over the splined end - I really don't want to risk dismantling the shaft and risking damaging it, then having to replace both wheel boxes. Somebody else must have replaced these rubbers at some point - I can't believe that I'm the first!
  4. #4
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,081
    Thanks Thanks Given
    142
    183
    Thanked in
    This UK supplier has all kinds of great stuff.
    https://simplybearings.co.uk/shop/
    These v-rings look good:
    Idea: if they won't stretch over the splines, you could cut with a razor and hold around the shaft with zip tie or wire.
    Edit: body copy says they are stretchable.
    Please let the Forum know your solution.
    Steve Gerow
    Altadena, CA, USA
  5. #5
    Join Date
    Nov 2011
    Location
    Martinsville NJ
    Posts
    505
    Thanks Thanks Given
    4
    Thanked in
    O ring that stretches . If you must cut it,
    use a diagonal cut so ther is overlap. There is o ring adhesive ( like crazy or super glue ). Heat shrink tubing is also great to work with - large sizes available.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
