Windscreen wiper wheelbox rubber shaft seal
Tricky
Hi guys. The rubber seals that fit over the wiper wheebox spindles on my BJ8 have perished and allow water to run down the shaft and drip inside my car so they need replacing. I haven't found any parts supplier that sells these but I have read on the MGA site of someone dismantling the wheel box to remove the shaft to replace it - I don't want to risk that but wondered if anyone else had obtained any rubber seals and just stretched them over the splined head onto the shaft, or achieved a seal some other way? BTW I'm not referring to the flat rubber gasket that fits on the shroud. Richard in UK
steveg
Got this from AHspares' site; added the red callout. Is that the seal? Not sold separately. They want you to buy the wheelbox.
Looks like you'd have to pull the spline and add your own seal. Maybe some o-rings or pack it with waterproof grease.
T
Tricky
Hi Steve, thanks for the reply. That is indeed the part in question but strangely it isn't available separately despite being an item that deteriorates over time and crucial to the fight against water ingress! I suspect that I'm going to have to find some suitably thicker rubber or silicone sheet that I can punch a hole in and slide over the splined end - I really don't want to risk dismantling the shaft and risking damaging it, then having to replace both wheel boxes. Somebody else must have replaced these rubbers at some point - I can't believe that I'm the first!
steveg
This UK supplier has all kinds of great stuff.
https://simplybearings.co.uk/shop/
These v-rings look good:
Idea: if they won't stretch over the splines, you could cut with a razor and hold around the shaft with zip tie or wire.
Edit: body copy says they are stretchable.
Please let the Forum know your solution.
British_Recovery
Bronze
O ring that stretches . If you must cut it,
use a diagonal cut so ther is overlap. There is o ring adhesive ( like crazy or super glue ). Heat shrink tubing is also great to work with - large sizes available.
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
B Mini Windscreen Wiper Parking British Motor Corp 3
W Windscreen wiper -60 BT7 Austin Healey 1
Q TR2/3/3A Windscreen Wiper Stroke TR3A Triumph 20
chicken Windscreen wiper arm, what length Austin Healey 9
angelfj1 Recommended Lubricant for Lucas Windscreen Wiper Restoration & Tools 4
Shinsen774 Windscreen Wiper Direction MG 39
M Spitfire windscreen wiper switch for '69 Spit Triumph 7
angelfj1 TR2/3/3A LUCAS Type DR2 vs DR3A Windscreen Wiper motors Triumph 5
jjbunn Windscreen Wiper Parking MG 10
Editor_Reid BJ8 Windscreen Wiper Dimensions Austin Healey 3
W Windshield / Windscreen Wiper Motor Austin Healey 1
B Windscreen Motor Repair Restoration & Tools 6
RCarr Windscreen Glass Options Austin Healey 2
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
W Tudor windscreen washer bottles Spridgets 0
Popeye TR4/4A Tonneau snaps by windscreen Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
K TR2/3/3A I saw a 59 TR3 today with an aluminium windscreen! Triumph 5
A MGB MGB 1974 windscreen centre rod replacement MG 5
71TR6 TR2/3/3A New Windscreen Glass quality Triumph 6
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
LAW75 Repairing Windscreen Scratches Austin Healey 10
Healey Nut BT7 Windscreen Pillars Austin Healey 4
G windscreen problem Spridgets 1
M Windscreen Wipers Parking Spridgets 4
M General MG Magnette windscreen washers MG 1
B TR2/3/3A Windscreen galss replacement Triumph 5
R Windscreen Glass Austin Healey 6
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
J Wanted TR3 Windscreen guide plates Triumph Classifieds 7
R BJ8 Windscreen Change Austin Healey 2
C Folding Windscreen Austin Healey 20
P For Sale tr6 windscreen Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
bugedd Measurement of windscreen glass Spridgets 7
K TR2/3/3A Windscreen seal Triumph 16
4tecdog Frogeye Windscreen Spridgets 3
Jim_Gruber Free Spridget Windscreen available - Dayton OH Spridgets 3
K Windscreen Washer Question Austin Healey 26
M TR4/4A Windscreen capping Triumph 0
G TR4/4A Inside Windscreen Capping Triumph 6
B Windscreen washer pump upgrade Austin Healey 10
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
CJD TR2/3/3A Windscreen Tenax Triumph 22
B TR6 Windscreen removal advice Triumph 10
