Seat Bottoms And Bases Don't Seem To fit Together Well
PeterB
Is it me or do the seat bottoms and bases don't seem to fit together too well in a BJ7? Could it be that my bottoms are wrong for base?
Frames look OK to me (working from memory, though). Plus, they look to be Kilmartin parts, which are usually pretty faithful to original. My bet's on the pan.
RAC68
Hi PeterB,
When viewing your pictures, your metal pan seem to present an aggressive turn at the problem corner with an easier turn at that point of the frame. As my original seat pans and frames have the same mismatch and fit well together, I must assume this match is common to all metal seat pans and frames. So, if my seat pans fit securely in their frames after pushing the upholstered pans back under the back support tabs (tabs shown in your picture), I suspect that your upholstery is stopping the pan from sliding all the way back under the tabs to clear the front of the frame.
Ray(64BJ8P1)
RAC68
Hi Derek,
I also noted the difference in angle between the metal pan and frame (a badly designed match). However, as my seat pans and frames are original, have the same dissimilar angles as pictured by PeterB, and have the pan sitting within the frame, I must consider that there is another issue at play. My thought is his upholstery is keeping the seat cushion/pan from sliding back far enough under the frame tabs.
Just my thoughts,
Ray(64BJ8P1)
GBRandy Wedge TR8 [TR7] Seat Bottoms Triumph 8
D Bugeye seat bottoms Spridgets 11
John Moore Bugeye Seat Bottoms / RHD Dash Spridgets 1
R Seat Bottoms Triumph 11
B WANTED: MK1 Seat bottoms Spridgets 12
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J TR4/4A TR4A seat retaining clip Triumph 5
R BJ7 Back Seat-Rest Austin Healey 1
A TR2/3/3A Seat position Triumph 2
