TR2/3/3A The timing mark on the crank pulley....
TR3driver
Great Pumpkin - R.I.P
There is only one mark, which should be TDC (unless someone has assembled the pulley wrong).
The advance curve starts really low on these engines, making it difficult to accurately set initial timing with a light. My suggestion is to start at about 3/16" from the TDC mark (which is about the 4 BTDC called for in the book), and then advance it a degree or two at a time until you can just force the engine to ping a little, by using heavy throttle at low rpm (30 mph in 4th gear) with the engine thoroughly warmed. Then I like to back off by about 2 degrees (half of a hash mark on the distributor vernier), just to be safe.
K
karls59tr
Bronze
Just speculating: Would a motor with a mild street cam and headers take 8 degrees advance?
CJD
It's possible. The initial recommended setting is a starting point. The final determination for spark is during driving tests. With the engine fully warm, tranny in 3rd or 4th gear, and about 2000RPM, floor it and see if you get detonation (pinking according to the manual). If you don't, you can use the Vernier on the dizzy to advance a degree or so...then try the test again. Once you do get the detonation, back the timing off a degree or 2 and you have the optimum timing for your engine.
Oh, in the picture above, Advanced would be with the crank circle to the left of the indicator. Retarded would be to the right.
poolboy
Even if you had a bunch of marks on the damper like a TR6 indicating theoretical degrees that #1 piston is from Top Dead Center, you'll see that the word "nominal" is used in this Haynes manual
l
RandallRK Timing mark on crank pulley Austin Healey 19
K TR2/3/3A Timing mark..... Triumph 1
R TR4/4A TR 4 Timing mark Triumph 10
A TR6 Timing mark Triumph 16
pkmh Setting Timing Mark For BJ8 Austin Healey 9
rlich8 Timing Mark Moving Around Triumph 21
C Timing Mark Spridgets 12
T Hmmm - no timing mark on the pulley. Now what? Spridgets 10
D BT7 Timing mark and pointer question Austin Healey 6
Bruce Bowker ignition timing mark Austin Healey 5
J 100/4 timing mark relocation Austin Healey 2
jbowlby Timing Mark Relocation Spridgets 5
D timing mark Spridgets 12
tony barnhill Timing Mark Relocation Spridgets 2
mgb4tim Wedge TR7 Timing Mark Triumph 0
Woodie timing mark - found Spridgets 10
Woodie timing mark Spridgets 42
1973purplemidget Timing Mark MG 3
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
