Steering rocker shaft - chemical rebuilding
steveg
Hoping someone with a worn sealing surface and a lathe will try rebuilding with Loctite Fixmaster metal rebuilding product.
See pdf p12 for rebuilding worn shafts. Downloadable pdf.
https://www.classccomponents.com/wp-content/uploads/2017/06/Loctite-Fixmaster-Metal-Rebuilding.pdf
Other repairs such as keyways and broken castings covered, too.
vette
Steve, Looks like good stuff. Do you think it is any different that JB Weld? I onced fixed a cylinder head on an MG Midget some 25 years ago with JB Weld. I know the car and owner and it is still on the road with no additional repairs. But I must say that the repaired area was not subject to movement or a rotating force such as a running shaft on a seal. But it was on the underside of the head right next to a combustion chamber. I meticulously filed the profile so the combustion chamber would seal.
steveg
steveg
Don't know about JB Weld for that. Would it contain enough steel to be properly hard against the wiping of the seal. The Loctite product is made for this use.
In the past, I'd seen something about this Loctite product being used to repair large shafts in place, maybe at power plants or pumping stations.
One's lathe would have to have the ability to grip the rocker shaft with the rocker inside the chuck. Or maybe one could make an extension to grab the threads so that one could turn down the affected sealing area and install the product, then turn it down to the original specs.
Surely once one got the surface properly finished, the action of the steering seals would be fairly low-stress compared to a whirring shaft on a pump.
vette
I just got an email response from one of my esteemed colleagues who noted that JB weld will withstand up to 500* and this stuff not near that amount. Maybe that's why the JB Weld worked on the cylinder head.
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
