Results 1 to 6 of 6
Thread: PDWA Issue
  1. #1
    Join Date
    Feb 2020
    Location
    Old Dominion
    Posts
    39
    Thanks Thanks Given
    1
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    PDWA Issue
    My PDWA shuttle is off-centered, and has been for a few years, just finally getting around to this and other things. I'm not really familiar with this item. I'm pretty sure it's moved to the rear brake side, because when I remove the plastic switch, I see a small gap to the right that I can just barely get a small point into. However, I cannot get it to budge to the left with the tool. So it occurred to me that opening a front bleeder might help .. nope. So just now I asked my son to press the brakes while I again opened the left front bleeder, we did the routine twice, still no shuttle movement.
    Thoughts? Hoping it's not stuck b/c of my neglect, and that I don't have to R+R it. Thanks.
    Martin Secrest
    Arlington, VA
    72 Triumph TR6. It's cool.
  2. #2
    Join Date
    Feb 2020
    Location
    Old Dominion
    Posts
    39
    Thanks Thanks Given
    1
    1
    Thanked in
    1 Post
    Re: PDWA Issue
    I guess the shuttle is jammed to one side. Next thing I'll try is opening both front brake bleeders and try centering the shuttle again with the brake pedal. For those with experience, is this more easily accomplished with two brake bleeders open, rather than just one, as I've already tried (and failed with)?
    Also, am I correct that the little tiny gap I'm seeing thru the switch hole on the right side of the shuttle (and into which I can get a tiny tool) means that that is the side to which the shuttle has moved? I don't see the same gap on the left (front brake) side of the shuttle thru the switch hole.
    Martin
    '72 TR6
  3. #3
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,775
    Thanks Thanks Given
    22
    17
    Thanked in
    Re: PDWA Issue
    Trace back the hydraulic line from the PDWA to the Master Cylinder.
    The forward line on the M/C is for the Rear brakes...Knowing that might help you determine to which end of the PDWA the shuttle shifted.
    DRIVE 'EM IF YOU GOT 'EM
  4. #4
    Join Date
    Feb 2020
    Location
    Old Dominion
    Posts
    39
    Thanks Thanks Given
    1
    1
    Thanked in
    1 Post
    Re: PDWA Issue
    Right, I did that, and on my '72, looking down at the PDWA, the rear brake lines are to the right, the fronts to the left. As best I can tell the shuttle has moved right, so I've been bleeding the fronts, but to no avail. I'll try the rear on the off chance I'm wrong, but I think I just have to pull the unit and rebuild. ****.
    Martin
    '72 TR6
  5. #5
    Join Date
    Feb 2020
    Location
    Old Dominion
    Posts
    39
    Thanks Thanks Given
    1
    1
    Thanked in
    1 Post
    Re: PDWA Issue
    And really, we're censoring d a m n here? Dayam.
    Martin
    '72 TR6
  6. #6
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,253
    Thanks Thanks Given
    52
    Thanked in
    Re: PDWA Issue
    Hopefully some of the links below will prove helpful as you work through the PDWA.
    From the Buckeye Triumphs website:
    https://static1.squarespace.com/stat...r+%26+PDWA.pdf
    If you find after working on the PDWA that you need to machine a new piston for it to use o-ring seals... see the archive link below from Buckeye Triumphs:
    http://web.archive.org/web/200305061.../PDWA/PDWA.htm
    And from restoration blogs:
    https://72triumphtr6.wordpress.com/2...toil-light-on/
    and
    http://www.74tr6.com/pdwa.htm
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
