General TR Dot 4 Brake Fluid
KVH
I just read a long series of comments/a blog about synthetic Dot 4. A number of folks say you can’t use that Dot 4 without first replacing wheel cylinder and master cylinder seals with non-rubber composition, and even then I should expect to be addressing leaks. What? Really? Why bother? Shouldn't we just hunt down a non-synthetic Dot 4 if it exists and can be found.
TR3driver
Great Pumpkin - R.I.P
LarryK
Used to be DOT 3 was used in the US domestic cars for the use of neoprene seals in brake systems. DOT 4 was used in European cars because of rubber seals. I don't think it matters anymore. I have always used the Castrol DOT 4 for everything. Bought a newer Rover and it says use synthetic DOT 4 and showed a black Castrol bottle. Went up to Ford dealer and asked for a bottle of synthetic DOT 4 as Raptor systems are close. Parts guy said they don't use synthetic. So I ordered in new bottles of Castrol. Then I looked at one of my old white bottles and it too said synthetic. Well, went to Advance Auto and there was Firestone synthetic DOT 4. DOT 4 has a higher heat tolerance and moisture control. For racing the Ford truck brake fluid has a really good heat tolerance.
KVH
KVH
Yes I’m good with Dot 4 as well. I was reading too many disparate complaints, stories and woes about isolated experiences and a lot of confusion between synthetic and silicone. MOSS has a good article in the subject.
Gosh, I’ve been absorbed in other matters and it’s sinking in that Blaine Graham retired. I’d been learning from him for a long time. And from many more here, and you know who you are. Keep driving TRs.
martx-5
You mean the earth ain't flat??
TR3driver
At the risk of sounding like a former president, that depends entirely on what definition of "flat" you use.
Merriam-Webster gives
and
So by those definitions, the earth is pretty near flat!
sp53
It is flat; how else are you going to have horizontal? Do you think everything will return at the finest infinitesimal angle from infinity to go full circle?
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
C TR6 TR6 with dot 5 brake fluid Triumph 8
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
CJD DOT 5 Brake Fluid Triumph 38
Jim_Gruber Brake Fluid - Castrol LMA Dot 3 or Dot 4? Spridgets 2
dklawson New Brake MC & Warranty with DOT-5 Fluid? Triumph 41
J dot 4 brake fluid Other Cars 4
M Dot brake fluid, question Spridgets 10
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
S dot 5 brake switch Triumph 14
S DOT 3 or DOT4 Brake Fliud Triumph 44
AUSMHLY Castrol DOT 4 vs Other Brands Austin Healey 6
R TR2/3/3A Dot 5 Triumph 8
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
Rhodyspit75 DOT 5 and DOT 5.1 Spridgets 1
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
S TR2/3/3A Question on the lift dot fastener, Triumph 3
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
T TR2/3/3A Lift the Dot question Triumph 4
TulsaFred Timing Gears dot to dot Spridgets 9
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
NutmegCT brakes: DOT 3 or DOT 4? Restoration & Tools 2
C TR6 Dot 5 in a TR6 rebuild Triumph 17
M Tennax and Lift A Dot? Spridgets 2
M Lift-the-dot peg Triumph 3
Tinkerman TR2/3/3A TR 3A Lift The Dot Studs Triumph 3
C Converting to DOT 5 Triumph 6
Steve_S The New M.G. Nuts dot com MG 1
M Removing Lift-the-Dot Fasteners Triumph 8
tahoe healey DOT 5 going away? Austin Healey 8
luke44 TR2/3/3A TR3 Lift the Dot Studs - 2 styles? Triumph 4
bighealeysource Push the Dot post on dash of BN6/BN7 Austin Healey 1
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
C "Lift-a-dot" studs Austin Healey 9
ekamm lift-a-dot studs Triumph 8
Brosky Stag Trimph TransAmerican Stag pics added to DOT Triumph 24
davidk Flushing DOT 5 Fluid Triumph 5
H TR2/3/3A TR3A - HOW MANY LIFT THE DOT PEGS ON CAR Triumph 4
dklawson A-Series Dot-to-Dot Cam Setting [TDC?] Spridgets 3
Brooklands Lift the dot fasteners Restoration & Tools 8
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
Harry_Ward Lift the dot stud type for tonneau cover? Triumph 13
Trevor Jessie 4 year old dot dissappointed with steering wheel Spridgets 4
G Dot Snaps Triumph 2
C DOT 4 vs DOT 5 Triumph 14
