Difficult Electrical Problem in 59 BE with Generator
mxp01
All:
I experienced the following electrical problem on my 59 BE with a generator:
When I turn the car on and start the engine everything is fine. When I begin to drive the fuel gauge needle begins shaking erratically. Simultaneously, the directional signal indicator gets really weak. As I go faster the fuel gauge goes to zero and the directional signals stop entirely. Stop the car and everything returns to normal.
I went under the dash and tightened everything. The fuel gauge bracket is tight and grounded on to the dash. Previously it was loose and it's lamp was flickering. I didn't find any other loose wires nor exposed wires.
The electrical system was operating fine until this afternoon. As I noted, when I have the car in the garage and parked, turn on the key - everything is fine. If I start the engine still everything is fine. When I begin to back out (increasing load on the engine) the fuel gauge begins jumping. However, while the car is stationary and I rev the engine, everything appears normal.
I live in Barbados. The environment is much like south Florida - high humidity. Add in horrible, washboard roads that shake the bee-jeezus out of the car.
I'd prefer not to drop the tank to check the ground wire.
Thoughts?
MXP
Bayless
You describe it as caused by the car actually moving. Sure sounds like a loose connection, could be a ground. I wouldn't first suspect the gauge ground wire since it affects your turn signals too. check the generator and regulator wires and the fuse box. Try turning on the headlights and see if that is affected too.
LarryK
Check that regulator is adjusted properly. Might have to clean the regulator.
Jim_Gruber
It’s possible to break the wires connecting the external connection to the internal generator wiring by overtightening and not using two wrenches on the nut where the wires attach of the end of the generator. You could have twisted the wires and have a broken wire inside of generator?
SaxMan
Not sure if the '59 had the ball and socket type connectors. I would hit them with Deoxit 5, a contact cleaner. If there is an inline fuse holder anywhere in the circuit, that can also be a trouble spot. I would also check the wire insulation for any wear or chafing. Even a little bit of exposed wire can cause an intermittent short. Those were the culprits when electrical gremlins started rearing their head on my '69.
M
mxp01
Thanks, everyone, for your assistance.
I believe I found the problem - there was a loose screw in the fuse block, one that secured a green wire on which included the fuel gauge. I tightened it down and it seems to have corrected the issue.
Thanks again,
MXP
bigjones TR2/3/3A Difficult to engage Reverse Triumph 15
R difficult bolt access Spridgets 8
D TR2/3/3A Getting difficult to start. Triumph 6
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
R Very Difficult cold weather starting problems! Austin Healey 21
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
M BJ8 difficult to start Austin Healey 25
NutmegCT A difficult "lie" Other British Cars 5
I TR6 TR6 difficult to start - ideas? Triumph 6
J Difficult Shifting Triumph 8
K TR4/4A How difficult is to remove 4A dash for refinish? Triumph 8
L How difficult is it to lower or raise your top? Austin Healey 15
L Difficult to engage second MG 4
tweety the difficult diff.... again? Spridgets 6
George Zeck Difficult / No Start when warm ??? Spridgets 11
R 74 B starts stops then difficult to start again MG 11
D MGA Difficult Starting MGA 1500 MG 6
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
