BN6: Shock absorbers do not fit after renewing the link arms
BN6_2197
Gents,
after renewing the link arms, the shock absorbers do not fit to the frame anymore. With the old ones everything is fine. Any ideas?
You can find pictures of the problem as well as the old and new link arms attached.
Cheers,
Volker
Bob_Spidell
What do you mean by 'renew?' The 'old' and 'new' links look to me to be completely different; i.e. the old are cylindrical, and the new are barrel-shaped, and appear to have welded seams. Also, from measuring my screen with a tape measure the new appear to be about a quarter inch longer socket-to-socket (that could cause the cocking of the shock body.
Do you mean replaced, by chance?
Jack T
It looks like the center-to-center dimension of the new link is greater than the old one. Measure them to confirm.
Bob was quicker than I was.🙂
red57
I agree with Bob & Jack on center-to-center dimensions, they do not look the same in the pictures anyway.
It also looks to me like the diameter of the tapered pin on the black ones may be a fatter taper which would alter the depth of insertion into the shock arm?
Dave
steveg
The studs are painted - those on the links. The unpainted others in picture 3 are bolts.
IMO, the fact that the taper doesn't seat as far as the original is probably the problem. The link being a little longer just positions the shock arm at a slightly different vertical position.
I'd remove the paint from the tapers, then measure the min & max diameters, comparing to those of the originals.
BN6_2197
BN6_2197
As steveg said, the gap is larger with the new link arms. Do I have the correct shock absorbers for the BN6? I have Armstrong Part No 5550*2 and 5550*3 (see picture attached).
BN6_2197
BN6_2197
Gents, can anybody tell me if this is the correct positioning of the uppet stud of the link arm? Or must the mount of the leaf spring contact the nut of the link arm?
What is the way to bring the link arm in the right position at the mount of the leaf spring? Ca I use a hammer?
Cheers,
John Turney
Volker,
There should be a distance tube, Moss#725-130, between the two ears on the axle. The upper stud goes through it. Tightening the nut while holding the hex section on the stud should pull the stud into place.
BN6_2197
BN6_2197
Gents, after cleaning off the paint and tightening the nut of the upper stud very hard, I was able to bring the link arm into the right position at the leaf spring. Unfortunately after adding the shock absorber I face the same problem as with the old link arm: the upper stud was squeezed out to the right of the upper cylinder of the link arm :-( Actually this was the reason why I started to replace it.
Is this expected or at least"ok"? Please note tghe distance of the lower cylinder of the link arm and the lever of the shock absorber.
Volker
Not wishing to complicate things, but since it hasn't been mentioned...
The stud going through the axle (with the distance tube) and for that matter, the tapered stud going into the shock arm, should not be tightened down until the weight of the car is resting on the wheels (in other words, sitting at normal ride height) or the rubber bushing longevity will be compromised.
A rubber bush does not rotate as the body of the car moves up and down over road bumps, it flexes, or twists. If you tighten those links down when the wheels are off the ground, the rubber bush will already have some of its twist being used. When the car goes over a bump and the suspension is fully compressed, the bushing may be twisted beyond its engineered range of flexing.
On the other hand, if you enjoy doing the job(s) often, don't worry about it... :devilgrin:
BN6_2197
BN6_2197
Volker
View attachment 62947 View attachment 62948
Does anybody have an answer or meaning to my „distance“ problem?
Randy, thanks for this valuable hint :encouragement:
Volker
GregW
Platinum
It was mentioned earlier to get measurements of the stud diameters. The taper in your first photo looks more drastic on the new piece. Also much wider.
steveg
Volker
A) Is the replacement from one of the regular suppliers - AHspares for instance? If so, maybe that's the only one available out there. If not, suggest returning it and sourcing a good one - as it clearly doesn't fit properly.
Can't tell from the pic if the tapered stud is seated in the shock arm and can be bolted up solidly with the shock bolted to the chassis.
B) If A) is not an option and everything bolts up solidly - with the car on the ground per Randy above - it should work.
red57
I still think the taper on the link pin doesn't look right but that could just be the picture.
One way to check the stress level on the link is to install the link in the axle bracket and the shock arm (not completely tight as Randy suggested, but snug enough to make sure it's roughly where it will be when fully tightened) while the shock body is loose/unbolted. The shock should sit in it's normal location when the link is connected... ie, there should be no strain sideways on the link in order to tighten the shock mounting bolts. If there is any sideways strain, the rubber in the links will not last long.
Dave
prb51 BN6 Owners Handbook Austin Healey 14
prb51 BN6 Wheel/Tire Combo Austin Healey 26
nevets BN6 Soft Top Webbing Austin Healey 2
BN6_2197 BN6 Static Timing Austin Healey 2
BN6_2197 BN6 Pulley Diameter Austin Healey 3
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
nevets BN6 horn button Austin Healey 17
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
G BN6 Battery location Austin Healey 7
C How to remove entire dash panel on BN6? Austin Healey 4
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
G Rollover Bar BN6 Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BN6_2197 Seat belts in BN6 Austin Healey 15
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
V Wanted BN6 Front Seats Austin Healey Classifieds 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
maxwedge5281 modified bn6 history Austin Healey 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
M First steps ... & BN6 Austin Healey 4
nevets BN6 rear brake pipes Austin Healey 15
C Healey BN6 water pump and overheating problems Austin Healey 11
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
BN6_2197 Adjustment of the Ignition System of my BN6 Austin Healey 22
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
maxwedge5281 bn6 two seater trunk Austin Healey 16
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
C routing of speedometer cable on BN6? Austin Healey 11
BN6_2197 Sun Shades for BN6 in Germany Austin Healey 3
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
A BN6 Top Installation Austin Healey 1
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
BN6_2197 BN6 brakes not working properly Austin Healey 9
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
David Townsend BN4 and BN6 Limited Edition Prints Austin Healey 30
BN6_2197 Distance Peace bearing for BN6 with whire wheels Austin Healey 10
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
BN6_2197 Removing the Swivel Pin of BN6 Austin Healey 5
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
maxwedge5281 bn6/7 hardtop Austin Healey 18
maxwedge5281 changeover to negative ground in my bn6 Austin Healey 9
