Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Fuel pump racing, no gas
  1. #1
    Darth Vader longbridgehealey's Avatar
    Join Date
    Apr 2006
    Location
    The Villages, Florida
    Posts
    2,545
    Thanks Thanks Given
    2
    Thanks Thanks Received
    3
    Thanked in
    At idle the BN4 fuel pump will click as fast as it can, but the car acts as if it is fuel starved. New in line fuel filter. Help?
    Thanks!
    Never tease an old dog, he might have one bite left.
    Ignorance is curable, stupid is forever.
    Women and cats will do as they please, and men and dogs should relax and get used to the idea.
  2. #2
    Obi Wan LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    2,059
    Thanks Thanks Given
    21
    Thanked in
    Re: Fuel pump racing, no gas
    New pump? Old pump? Might have lost the flexibility in pump valves. May have hole in suction side of pump. Fast pump means it isn't filling carbs. May have hole somewhere between pump and carb. Follow line from tank forwrd. Easier if it isn't dumping on floor, would in tank or pump. Also, just talking, does tank have fuel in it or did someone steal it while garage door open.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual (parts car),
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  3. #3
    Join Date
    Apr 2006
    Location
    Posts
    2,545
    Thanks Thanks Given
    2
    3
    Thanked in
    Old pump, no leaks thinking pump. Tank full, just did it🙃
  4. #4
    Jedi Warrior roscoe's Avatar
    Join Date
    Jun 2004
    Location
    Esparto, CA
    Posts
    777
    Thanks Thanks Given
    1
    13
    Thanked in
    If all you did was put in a new filter and it was fine before that, is the filter directional, is there any sort of check valve in it? If there is and it is in backwards it possibly could cause your symptoms. Many inline fuel filters have check valves to keep pressure in fuel lines or rails and prevent vapor from forming after shutdown. Often there may be an arrow on the filter body that shows fuel direction of flow. If it were in backwards it would prevent the pump from pulling fuel from the tank and perhaps it leaks enough to allow idle because the is " pulling fuel past it" wheras normally it just would keep fuel from leaking back to the tank at almost zero pressure.
    Jon Robbins
    1956BN-2 (do it all yourself, you'll be glad you did)
  5. #5
    Jedi Warrior red57's Avatar
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    609
    Thanks Thanks Given
    10
    29
    Thanked in
    If the new in-line filter is between the pump and the tank, it could be a fitting leak - it's possible to have a leak that sucks in air but doesn't leak gas out.
    Dave
  6. #6
    Join Date
    Apr 2006
    Location
    Posts
    2,545
    Thanks Thanks Given
    2
    3
    Thanked in
    Hi Dave, filter down line from pump. Checking filter for direction.
  7. #7
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,090
    Thanks Thanks Given
    145
    183
    Thanked in
    LBH - did you get a resolution?
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  8. #8
    Obi Wan RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    2,149
    Thanks Thanks Given
    29
    Thanked in
    If I presume correctly and you installed the filter between the tank and pump, I would follow Jon and Dave's suggestions and check the direction of the filter and assure you are not sucking air through a leaking fitting. Also, if you cut the line between the tank and pump, you have severed the ground connection for the gas float sending unit. I would install a new ground line from a gas tank sending unit cap screw to a solid body ground or you may not have a gas gauge reading anymore.<br>
    <br>
    Ray(64BJ8P1)
  9. The Following User Says Thank You to RAC68 For This Useful Post:
    steveg  (03-14-2020)
  10. #9
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,090
    Thanks Thanks Given
    145
    183
    Thanked in
    Quote Originally Posted by RAC68 View Post
    ...Also, if you cut the line between the tank and pump, you have severed the ground connection for the gas float sending unit. I would install a new ground line from a gas tank sending unit cap screw to a solid body ground or you may not have a gas gauge reading anymore.<br>
    <br>
    Ray(64BJ8P1)
    Good advice for anyone.
    Steve Gerow
    Altadena, CA, USA
  11. #10
    Join Date
    Oct 2014
    Location
    Western Canada
    Posts
    526
    Thanks Thanks Given
    4
    3
    Thanked in
    If the filter is down stream from the pump, as it appears to be, installing the filter backwards should not cause the pump to continue clicking/running. For some reason, the pump is not building pressure. Since the fuel is not leaking out under the car or in the engine compartment, obviously, the pump is not pulling fuel from the tank. That likely means a tank or fuel line blockage upstream or a bad pump.
  12. #11
    Join Date
    Apr 2006
    Location
    Posts
    2,545
    Thanks Thanks Given
    2
    3
    Thanked in
    Ok, finally a solution. Pump failing. Replaced pump and all is well. Took an extra day to respond, we are also in the process of moving. Drove the Healey today from central FL to the Gulf Coast, our new home in Palm Harbor. Thanks to everybody for all the help!
  13. The Following User Says Thank You to longbridgehealey For This Useful Post:
    John Turney  (03-15-2020)
  14. #12
    Member madhouse's Avatar
    Join Date
    Mar 2014
    Location
    Littleton, CO
    Posts
    40
    Thanks Thanks Given
    10
    1
    Thanked in
    1 Post
    Good info here. My BN-4 was rebuilt 2 years ago - been running great, even in hot 90 degree weather. But yesterday on a 30mile drive in 75 degree weather it had all the symptoms of vapor lock. Full tank, starving for fuel. Could restart after short stop, but not apply much demand on carbs. As soon as i did, it died. Finally I opened the hood and the took off rear seat cover (above fuel pump), let it sit for 45 min, and it ran fine for the rest of the way home. My fuel pump is only 2 years old. Could it have just been some heat in the wrong spot to vaporize fuel this time? First time its happened. I'm thinking about covering all my fuel lines with some heat resistant sleeves, maybe the fuel pump and part of carbs. is that overkill? I will also go back and look for air leaks, never saw any fuel leaks. Engine temp was within range (180degrees).
  15. #13
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,194
    Thanks Thanks Given
    5
    60
    Thanked in
    Quote Originally Posted by madhouse View Post
    IIRC, older sixes, like the BN4, had the fuel line on the same side of the exhaust (my BJ8 has its pump on the passenger side). My experience--with a BN2 and a BJ8--is that the 'vapor lock'--'cavitation,' etc.--occurs in the engine bay, esp. with the carbs sitting on the exhaust manifold (but putting a fuel pump above the exhaust pipe isn't a good idea--Geoff must have been absent that day). My guess is something is opening up somewhere between the tank and the pump--that's when you usually get a racing pump--though what it could be, I have no idea. I think the ambient temp is irrelevant (again, just a guess).
    We put a (supposedly) good used tank in our BN2, and we were stumped by erratic fuel delivery until my dad cut the old pipe off the tank and found some corrosion at the joint--Dad figured it was probably from the flux used to solder the line to the tank--where there was a pinhole leak. Drove a couple fuel pumps crazy. Also, I remember an old article in 'Skinned Knuckles' where the author bought an old Caddy--I think--on the cheap because it would stumble badly at highway speeds. Eventually the author found a small dent or kink in the fuel line; when hot, the fuel would cavitate after the dent/kink and vaporize the fuel supply.
  16. The Following User Says Thank You to Bob_Spidell For This Useful Post:
    madhouse  (05-02-2020)
  17. #14
    Join Date
    Mar 2014
    Location
    Littleton, CO
    Posts
    40
    Thanks Thanks Given
    10
    1
    Thanked in
    1 Post
    Bob Spidell,
    Thanks for your response. I have done a few things based on your notes:
    1) I found a few slight kinks in the steel fuel lines between the tank and fuel pump, so I cut out that section and used flex hose to the fuel pump (just another 3 inches from what was already there). unfortunately, that did not help.
    2) I had a backup Facet Fuel Pump that I have been carrying with me, so I installed it on the passenger side of the car behind the footwell (consequently further away from the tail pip/muffler). I thought I had it fixed, but after then engine reached operating temp for a while (20 minutes-ish) while driving in 70degree weather - the facet pump starting clattering louder similar to the SU. I did use the rubber buffers when installing the facet and the default 'click' was well deadened at first.
    3) Since I have a 4seater, I can easily check/trace the line all the way from pump to tank. I just can't see any points of leakage in the line. So i'm left with 2 more options - both of which you mentioned in your note on 5/1/2020.
    a) Perhaps I have a leak in the fuel line that extends into the tank, and when the fuel level drops below that leaking point, the pump is sucking air (?). or perhaps at the joint itself at the tank. This is only a 5 year old tank, but perhaps it was delivered with these defects - I've had the problem as long as I can remember. OR
    b) I need to do someheat isolation in the engine compartment, possibly with some creative use of DEI heat insulation for fuel lines and carbs.
    For now, I'm going to experiment and see if the clatter starts when my fuel tank is at a certain level, rather than driven by heat. If negative on that - I may be pursing a new tank. thanks for the info.
    Rob
  18. #15
    Luke Skywalker DerekJ's Avatar
    Join Date
    Nov 2004
    Location
    Cotswolds, UK
    Posts
    1,518
    Thanks Thanks Given
    7
    Thanked in
    Check to see if the fuel tank cap is venting properly. If it isn’t a vacuums effect is created. You will hear a pressure hiss when removing the cap. Just a thought, it happened to me.
  19. #16
    Join Date
    Mar 2014
    Location
    Littleton, CO
    Posts
    40
    Thanks Thanks Given
    10
    1
    Thanked in
    1 Post
    Thanks DerekJ. I hope it's as simple as that - I will do a bit of experimenting to see what happens. But I am using a new locking gas cap from Moss, so I suspect it is good. Will let you know.
  20. #17
    Join Date
    Oct 2014
    Location
    Western Canada
    Posts
    526
    Thanks Thanks Given
    4
    3
    Thanked in
    Have you checked the seal at the fitting where it exits the tank? You may not see fuel leakage there, unless the tank is completely full or over full, even if it is sucking air. That happened to me once. Didn't know I had a problem there until I completely filled the tank, including the filler spout.
  21. #18
    Join Date
    Mar 2014
    Location
    Littleton, CO
    Posts
    40
    Thanks Thanks Given
    10
    1
    Thanked in
    1 Post
    blueskies - thanks. that's a great idea. I do smell gas when I fill all the way, but just thought it was from the gas cap. I will check it out and let you know.
    Rob
  22. #19
    Join Date
    Oct 2014
    Location
    Western Canada
    Posts
    526
    Thanks Thanks Given
    4
    3
    Thanked in
    A gas smell when you fill the tank all the way can also come from a poor seal on the rubber sleeve on the fuel filler pipe or from a bad seal on the sending unit. The sending units can get bent around the edge, and a new seal won't work well unless the sending unit edge is carefully straightened. But that is a separate issue and would not account for the fuel pump running issue.
  23. #20
    Join Date
    Mar 2014
    Location
    Littleton, CO
    Posts
    40
    Thanks Thanks Given
    10
    1
    Thanked in
    1 Post
    Derek,
    I drove for about 40 miles today then checked the gas cap for the venting issue. I did not detect a vacuum effect in the tank when I removed the cap. Dang - I was hoping it was that easy! thanks for the suggestion anyway.
    Rob
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
