TR4/4A TR4 Fuel Gauge'"light bulb socket" type?
karls59tr
Bronze
I'm ready to put a TR4A fuel gauge,fuel sending unit and resistor in my TR3. Tested it on the bench and works good.The light bulb holder on the 4A gauge is a 1"x3/8" metal tube with 3 slits in the side. Anyone know what type of socket and bulb fits in there.? It's a completely different set up on the TR3.
charleyf
In the Moss catalog there is a picture of what you are looking for. Unfortunately it says N/A. Item 78.
https://mossmotors.com/triumph-tr2-3-4/electrical-ignition/wiring-harnesses-misc-electrical.
If you have access to any old behind the dash wiring harness from a TR4-6 you would be able to find one of these. It takes the same screw in bulb as found in the TR3. The difference is that the outer case is solid and smooth . The bulb screws into the holder and then the holder slides into the tube you describe.
Sarastro
It's a simple, cylindrical socket that takes a screw-base bulb. It just slides into that cylinder on the back of the instrument. Here is one picture, taken while I was installing my harness, showing a cluster of them; sorry, it's the best I have. The bulb was originally type 997; I'm using no. 1449, which is easier to find.
glemon
The bulb, admittedly the easy part, is a 12 volt e10 screw base, lots of options out there but you need one where the head or bulb part fits in the socket in the gauge.
Rut
Any idea where to get one?
Karl,
PM your address...I have one that I just tested and it’s a 2 wire style, just cut off the ground.
Rut
Rut
Karl,
Just checking in to see if you received the bulb and bulb holder and to check on your progress.
Rut
K
karls59tr
Bronze
Karl,
Rut
Hi Rut I haven't received it yet but I'll let you know when it arrives. Canada Post can be slow once it gets to the border. Does the gauge on the TR4 just rely on the the ground at the sending unit? On the TR3 I've heard it's necessary to ground the gauge as well?
Karl
Rut
Karl,
Im concerned about the affect that Covid 19 might have on packages crossing the boarder. If the gauge is grounded you can use the ground wire or use the gauge.
Rut
Rut
Karl,
Looks like it’s scheduled to be delivered on March 25th...
Rut
K
karls59tr
Bronze
That's OK I'm still tinkering around with the tie rod end and tie rod then I'll get to the gauge and bulb. Are you doing anything to your TR4?
Rut
Karl,
Funny you should ask...I’m actually in the process of selling some of my cars. I’m at the age of freeing my family from some of my ‘hobbies’, LBCs, guns, etc. I currently have 2 TR6s, 1 TR4 short bulge, 4 TR4as, 1 MGB, 1 Bugeye and a 1975 IH Scout. I have 1 more resto/restomod left in me and that will be a TR4a and I’ll keep the Bugeye and MGB.
Good luck on your tie rod and tie rod ends!
Rut
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
KVH TR4/4A Two TR4 Trivia Questions: Fuel Gauge and Shocks Triumph 2
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
J TR4/4A Auto Meter Fuel Gauge for TR4 Triumph 1
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
B Triumph TR4 replacement fuel tanks Restoration & Tools 3
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
A TR4/4A TR4 Fuel Pump Triumph 5
Kirk_Fisher TR4/4A Fuel mileage TR4 Triumph 17
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
TR4 TR4/4A TR4 Fuel Pressure Triumph 20
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
KVH TR4/4A TR4 Fuel Pump Triumph 9
SCguy TR4/4A Cork gaskets for TR4 fuel pump glass bowl Triumph 7
M TR4/4A TR4 Fuel Pump Rebuild Triumph 3
D TR4/4A Electric Fuel Pump for TR4 Triumph 5
SCguy TR4/4A TR4 Fuel line to fuel pump question Triumph 8
M TR4/4A TR4 Fuel Delivery Triumph 0
SCguy TR4/4A TR4 fuel line? Triumph 5
SCguy TR4/4A Fuel Tank, Fuel line question, TR4 Triumph 7
T TR4/4A Fuel line on TR4 Triumph 6
T TR4/4A Fuel tank on TR4 Triumph 0
J TR4/4A TR4 Fuel Line to Carbs question Triumph 2
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
Alan_Myers TR4/4A Fuel tank sending unit - TR4 Triumph 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
